RPM/Speed
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    RPM/Speed
    Ok everybody, what RPM does your bike run at when doing 60 mph? I've been thinking of doing the 750/850 final drive change, but the fact that my bike is a basket rebuild makes me question some of the parts that were installed by the P.O. It seems to me that 3900-3950rpms at 60 mph is a bit low! I was wondering what other bike run at so I can get a comparison. I picked 60 mph because it was a nice even number.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    4K @ 60
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    • red bandit
      • 970
      • central michigan
      3100 rpm at 60 mph. 850 final drive installed.
      79 SF parts bike.
      • Codger
        • Dec 2005
        • 27
        • Iowa
        RPM'S
        I'm turning 3500 at 60 mph with the 750 rear end conversion.
        • Toolmaker Tim
          • 671
          RPM/MPH
          Thanks, that answers my question. I guess the final drive is original.
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
          • randy
            • Dec 2003
            • 4521
            I have the 750 FD swap, and I run 3500 in 5th at 60MPH.
            • DavesXS
              • Jun 2008
              • 231
              • Matthews, NC
              You have the lowest rpm at 60. Is the 850 final drive the difference, or do you have a 17 or 18" wheel too? And what tire size?
              What ever you have to make it turn 3100 at 60 I need that too.
              • red bandit
                • 970
                • central michigan
                Don't know why mine is so low. I've clocked my speedo with a couple diff. newer vehicles. My rear tire is a Dunlop Elite 2 MT90 B17 76H Before the 850 FD swap I was running about 3600-3700 rpm at 60 mph. As far as I know the 750/850 are the same. I checked the ratio before I put the 850 on and it was what ever the 750 was. I have plenty of power to pass at 60 in 5th, course it's more fun to drop to 3rd. I get 39-40 mpg, doesn't matter if I run 60 or 85.
                79 SF parts bike.
                • dbeardslee
                  • 4385
                  • Maineville, OH
                  The stock FD is a 3.3:1 ratio, while the 750 and 850 FD's are 2.9:1.
                  • DavesXS
                    • Jun 2008
                    • 231
                    • Matthews, NC
                    Ok
                    Dunlop Elite 2 MT90 B17 76H is a 17" tire so your running a 17" wheel. Good, because I have a 17 sitting right here waiting for me to get a 750 FD and install them at the same time.
                    That tire is the same as 130/90/17
                    • Toolmaker Tim
                      • 671
                      If I remember correctly, the 17" wheel is the stock standard size, so I wouldn't be gaining as much in gear ratio with my 79SF. Therefore a slightly higher RPM/lower MPG. Can a 17" wheel be put on a SF? My gas milage is hovering around 33-34 mpg. I will be putting Elite 3's on soon I hope. The size would be the MT90-16's I believe. Like everyone else I am after the Holy Grail of Gas Milage.
                      1979XS1100SF
                      Jardine 4in1
                      Dunlop Elite 3's
                      142.5 main jets
                      45 pilot jets
                      750/850 FD mod.
                      XV 920 Needle Mod.
                      • DavesXS
                        • Jun 2008
                        • 231
                        • Matthews, NC
                        Mines a special I'm putting the 17 on. I been told I need to get dust cover and spacer that goes with it.
                        • Toolmaker Tim
                          • 671
                          If I'm understanding correctly, the only thing changed is the dust cover and a spacer to go to a 17? Yeah Yeah, I know, but if you use words with one syllable it's easier for me to understand
                          1979XS1100SF
                          Jardine 4in1
                          Dunlop Elite 3's
                          142.5 main jets
                          45 pilot jets
                          750/850 FD mod.
                          XV 920 Needle Mod.
