MPG and modifications poll
  • Montreux_Blue
    replied
    On the Talihina OK trip I got about 43 mpg going up there and about 32 mpg coming back. On the way up we went about 5 mph over the speed limit (75 mph max) and on the way back we ranged from 80 mph to 120 mph. The way back was a lot of fun and worth the less gas mileage! I've got stock exhaust, pod air filters with Ivan's mod and carbs up one jet size on mains.
    Leave a comment:
  • Yahman
    replied
    db_chambers, Nice to see a new member in this part of the country, welcome to the community.
    You're getting about the same mileage that I am. My XJ runs great, but the mileage could be better. I just got it running this summer and will have to live with it that way until the winter of 2009. That's when I plan on doing a complete frame up restoration.
    Larry
    Leave a comment:
  • xschop
    replied
    bad gas
    I see you live in Oregon. What is your altitude there. Also Oregon may have the same laws as Cantafordya for fuel additives. But your culprit just may be the coils. Go thru the steps to test them from the book specs. You would be surprised what a new set of aftermarket HP coild will do for these old bikes.....JAT
    Leave a comment:
  • dbeardslee
    replied
    Dave - You might check with Prometheus578 - He's in Olympia, and is affiliated with a motorcycle shop. He knows the 11's inside and out. I'd be careful about who I let work on a thirty year old motorcycle. $68 and hour seems reasonable, but not if your paying for someone's learning curve. Might be some other members in your area too.
    The trickiest part of doing the head is messing with the cam chain (need a chain breaker/riveter). The rest of it is pretty straight forward. There's plenty of good info on this site to get you through it if you decide to try. The great thing about winter is, with no one riding, you'll get really fast replies to your posts
    My advice is to do what you can yourself. Not just from the financial perspective, but because thirty year old bikes can be pretty cantankerous. It pays to know how to work on 'em, as you never know when some little thing will give you trouble on the road. I like to carry my mechanic with me.
    Leave a comment:
  • db_chambers
    replied
    Cylinder 1 has about 140 psi and the other three around 180ish, so I know it has that problem. Just dumped $1300 into getting it running. The mechanic mentioned something about sticky valves. I am not at all a good mechanic. How much should I expect to pay to have the head done? Shop rate is $68/hr. 27 mpg is better than the 16 I get with my diesel truck. Just thought it should get closer to 4o or so.
    Leave a comment:
  • dbeardslee
    replied
    Dave - This thread has some info on stuff that affects mileage - http://www.xs11.com/forum/showthread.php?t=746.
    Have you checked your compression? If it's been sitting for a long time, chances are the valve seating surfaces are pitted. I got a pretty good improvement in mileage after redoing my head. Lapping the valves, cleaning the valves and ports, replacing the stem seals, and setting the valve clearance paid off. Made it idle nice and smooth too.
    I think the head is one of the more neglected items when it comes to maintenance due to perceived difficulty (valve clearances are supposed to be checked every 6k). The carbs certainly have to be setup, adjusted, and synched correctly but the lift, duration, and condition of the valves controls how much of the fuel/air mixture actually makes it into the cylinder and has a big bearing on how efficiently it is converted into energy. If you're a decent mechanic, it's a pretty straight forward operation and a good project for those cold winter months. Something to think about.
    Leave a comment:
  • db_chambers
    replied
    Dave C
    I have a 79 xs eleven special, 8200 miles, all stock w/ K&N air filter, and I only get 25-27 no matter how soft or heavy I throttle it. Kinda sucks for my 45-mile commute each way! Have to fill-up sometimes twice a day. What can cause such poor fuel mileage? I am new to this bike, my dad's/garaged and rarely ridden since 1983. Carbs gone over by bike mechanic. Please help! Thx
    Leave a comment:
  • xschop
    replied
    lil' Acetone experiment
    After soaking some old float valves in a mix of 50% Acetone and 50% crap gas from lawn mower (has ethanol) for a week, I don't see any deterioration on the little black rubber (I think these were from an old set of Yammy carbs). I also soaked an old gas petcock gasket (XS1100) and some stock fuel line for the last few days.....no problems even at a 50/50 mix.
    Leave a comment:
  • Korr
    replied
    I actually live in union city. My commute to work is pretty straight forward, no hills or anything, just lots and lots of cars and even more cars. I take the 880 south to work. Maybe it's cause i'm thirty and lost my patience or something cause i can only stand going 65mph for so long hahahaha The last four bikes that i had before the xs one was the 250 rebel i could only go about 70 tops, the one after was a 1994 honda magna 750 which is just as fast as the xs, but ate up a TON of gas on the freeway, next was a 1992 FZR600 which made me know for sure that i end up hurting all over after a 30 minute ride on a sport bike, next was a 1982 920 virago that i was not happy with the power and mainly small fuel tank. All those bikes i didn't mind going 65-70, but the XS will not let me go at those speeds for longer than 3-4 minutes...weird!! It really likes to go at 75mph minimum
    oh btw, all of a sudden this week the bike is being more fuel effecient. i'm at 130 miles and could probly do a little more before reserve now woohooo!
    Leave a comment:
  • snowdog51
    replied
    ace
    tried it like it bike runs much better with
    car does to.
    bill
    thanks to chop
    Leave a comment:
  • xschop
    replied
    SF Gas
    Do they still add MTBE to your gas there? What's your ethanol % also.....
    Leave a comment:
  • dbeardslee
    replied
    Korr - Could have something to do with SF and all those hills you guys have to deal with. I wouldn't want to be the guy who had to buy brake pads in that town .
    Leave a comment:
  • Korr
    replied
    My 78E only gets about 27mpg average i think...i usually have to pump at 110 miles if i don't switch to reserve. Only mods are a kerker exhaust and octopus removal that was there two owners ago. No idea if it's been rejetted or not. I could probly get 30-35mpg if i stick with a constant 65mph speed. I'm always changing speeds. In the city i'm only going 40-45 mph tops(speed limit is 35-40). As soon as i am on the freeway i'll get her to 70, 75, 80mph. It will always go back and fourth between those 3 speeds. That's probly why my gas milage sucks so much compared to everybody here. So how fast do you guys go on the freeway/highway?
    Leave a comment:
  • xschop
    replied
    another test run
    In my 1995 Honda civic, last summer, I replaced the blown head gasket because she started overheating. While I had the head off, I polished the chambers/valve faces and lightly ported the intake runners to give them that "brushed" look ......I was getting 35 mpg's before the head job and K&N filter, then 37 afterwards.....I was very happy since it was almost 200K on the clock after the rebuild......This last week or so, I ran a complete tank (13 gal) of Shell gas with 3oz of Acetone to see what would happen......41 mpg's avg!.......with an engine of 208K miles.....Anyone up in the high altitudes trying this yet?
    Leave a comment:
  • dbeardslee
    replied
    Ryan - That sounds pretty good to me. The best I ever got was 37.5, and that was all highway. I usually average 32.5, but that's with some pretty aggresive throttle twisting.
    Leave a comment:
