I have 4 into 1 exhaust. The header part looks like garbage. I do not at this time have the funds to replace them. I was looking into possible cleaning them up and painting them with high temp flat black paint. Would this work?
Headers looking like crap.
header fix
as long as they are not rusted thru, paint them with the high heat ceramic paint, I just did mine after I cut them down and have been couple hundred miles with no problems....I will be header wrapping them next...chopMDRNF
79F.....Not Stock
80G......Not Stock Either....In the works -
I used BBQ grill paint. It's good up to 1500 degrees. I've used it on my old gold wing and it held up great. With most high temp paints you have to back the part after you paint it to get the paint to cure but not with the BBQ grill paint. Just scuff up the exhaust and paint it. Let it dry and install. It smells kind of funky the first time you run it but after that your good to go.
You should be able to pick it up and any hardware store. I got mine at walmart. It comes in a spray paint can.
WORK GOODComment
Laugh if you want but it's cheaper and easier to use then the hi temp engine and exhaust paints. And whats Wrong with Cooked weiners. Here in Wisconsin we perfer to cook Brats. But to each his own.Comment
