just finished my mod and also installed a 140/90-16 dunlop d404 rear tire.had rubbing at first then tried to find a good solution instead of trying to shim the fd.not recommend on my end so i removed my rear tire and heated the inside of the shaft housing.used a flatheaded air hammer and while cherry hit it with the air hammer.took it in about 1/16th of an inch.perfect fit.no more rubbing stll have full contact with the fd drive splines.no vibration or wobble.perfect solution for me.just wanted to let you guys know.happy riding.
