So clean it again
"I painted the pipes today with low gloss, hi temp manifold paint rather than go shopping for new pipes,"
Hi Cam,
some would consider semi-matte black pipes as an upgrade rather than an economy. If you have swapped #2 & #3 plugs & plug wires and the problem didn't change cylinders plus you got good readings on a compression test you know you have to clean the #2 carb at least one more time. Only when all 4 are running can you hope to balance the carbs properly.
Hi Cam,
