Here are my two dyno test. The one from October didn't quite make it because the clutch was slipping in the midrange but it still made 94.5 hp and 70.31 ft. lbs. of torque before the clutch gave it up. On Friday 7-18-08 sporting a new clutch I tried it again. The graph is not as clear as I would like but Widman's dyno printer wasn't very dark. The torque reading's should be divided by two and I have the correct numbers penciled in beside the really big ones. The final readings were 95.58 hp and 73.95 ft. lbs. of torque which is more torque than I expected and less hp than I wanted. I installed the intake cam at 5 degrees advanced which fattened up the torque but cost me some on the top end I believe. The carburetors are stock except for a main jet change and the air box has 3 one inch holes in the air cleaner base. I wanted a 100 hp and still think it's attainable but as of now this is what I have.
