I've recently rebuilt the petcocks an repainted the tank on my MNS. While I had all that off I took the oportunity to replace the coils, wires and caps with a set from MikesXS .. (direct bolt on for me). Also the PO had a small hose runing from the back of the bike to the #2 cylinder vac port and the vac advance capped off. I'm not sure what was plugged into it but i took that off and plugged the vac advance back in.
After putting it all back together, and putting gas in I noticed a sound.. a sound not unlike water pouring on plastic. I turn off the petcocks (They work now) and a little inspection the air box has gas in it..
I take it off, dry it out and put it back on I then turn on the petcocks while tapping (very gently) on the float bowls. This seemed to stop the pouring sound.
Ok now I turn it on and thumb the starter.... it roars to life like never before .. litteraly jumped to life and settles into a nice even idle at about 1100 rpms.
I reach down and turn the petcocks on and the engine starts to climb ... all the way to 7k rpm .. when i turn one of the petcocks off it takes a minute but will settle back down into an idle. turn it back on and it goes right back to 7k.
I have a few things i'm gonna try this weekend. Let me know if I'm warm.
1) the Vac Advance line may have a hole it it..the reason I assume this is because. I'll just cap it and the #2 carb vac port off.
a) if a float needle is not seating it should enrichen the mixture and cause a stumble if its not getting enough air.
b) the only thing (i'm a complete newb) i can think of is a float sticking or a needle not seating
2) take the carbs off and ever so gently clean the bowls and anything i can reach from the bowls.
I plan on sending these to 81xsproject for a good cleaning and adjustment, but untill I get the cash I'm hoping to at least get it rideable.
Any advise?
Any advise?
