Resurfacing discs
  • hobbsy84
    • Dec 2007
    • 46
    • Canberra, ACT Australia
    Resurfacing discs
    Just looking into the braking parts of the '81 Standard I'm rebuilding, and the next item on the list is the brake rotors. Poor things seen better days, to put it one way. They've seen a lot of weather, and not much use, so the rust has basically taken over. Due to this, there's a fair amount of pitting on them.
    What I'm wondering is, has anyone had brake discs for these bikes re-surfaced/ground down, and would there be limits to how much could be ground off?
    Current playthings:
    1981 Yamaha XS1100H - 1179cc Wiseco bore kit, 36mm ZRX1200 carburetors, damn thing has been completely rebuilt from the frame up. Yep, its been a long time coming.
    1988 Yamaha XT600 Tenere - She'll go just about anywhere!
    1986 Yamaha FJ1200 - The previous tourer, replaced by the XS11. Someone had to go.
    1974 Chrysler Valiant Charger - Because you can't only have 2 wheeled toys draining the cash.
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    See this
    Ernie
    • rbmgf7
      • Jun 2008
      • 39
      • Ohio
      i did this
      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
      which came out to this
      '79 XS1100F
        rbmgf7,
        As that seemed to work for removing rust off of a metal surface, I would NEVER recommend anyone ever doing that to brake discs. They need to be turned on a lathe to remain true. I can't even imagine what those are like under heavy braking.
        I'm really not trying to be a jerk or cut you down.. there is just a reason why people don't take their front discs off their car, set them in their laps, and start grinding the grooves off of them.
        That being said, I have heard that there are problems with turning the discs and having them warp afterwards. What you might try is turning them, then drilling them to help dissipate the heat to help with warpage.
        OR... looking on Ebay for some good used ones would probably be the cheapest route if that's what you're looking for.
        • hobbsy84
          • Dec 2007
          • 46
          Hmm, from the sounds of this, it sounds like it's time to go annoy the local wrecking yards again
          Thanks for the input though, guys.
          Current playthings:
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            They can be resurface but you need to find a machine shop that surface grinds rather than lathe turns them. Stainless steel doesn't cut well on a lathe like iron rotors used on cars and only a few bikes.
            The iron rotors on my old Guzzi worked fantastic but looked like crap if the bike sat more than 24 hours. I tried baking on black paint to cover the areas where the pads didn't ride and that only lasted a month...
            Geezer
            • XSPastor
              • Oct 2007
              • 602
              • Gaithersburg, MD
              FWIW - There's a guy on ebay the will grind them for you for 50 bucks each. ebay item number 300242345391.
              Tim Ripley - Gaithersburg, MD
              23mm float height
              120 main jets
              42.5 pilot jets
              drilled stock airbox with K&N
              Jardine 4 to 1 Exhaust
              spade fusebox
              1st and 2nd gear fix
              • andreashweiss
                • 951
                • 180 mile northwest of Spokane,WA
                And i can send you a left right front match pair of non slotted rotors with bolts and clips, awesome shape, last for yrs not grooved or warped, $100 includes ship to australia.andreas
                • hobbsy84
                  • Dec 2007
                  • 46
                  You've got a PM coming your way, Andreas.
                  Current playthings:
                  • GNEPIG
                    • Apr 2005
                    • 1657
                    • fl
                    XS1100 BRAKE DISC ROTOR MACHINE:
                    Buy and sell electronics, cars, fashion apparel, collectibles, sporting goods, digital cameras, baby items, coupons, and everything else on eBay, the world's online marketplace
                    Hey, that guy is back. Looks like he does good work, but his prices have gone up almost 20 bucks since I last seen this auction. Demand must be up.
                    Yeah, the same with the front rotor on my old 73 Norton.
                    • HobbyMan
                      MeatHead Idiot "GURU"
                      • Jul 2006
                      • 1801
                      • Colleyville, TX
                      So we can't turn these on lathes?
                      Acta Non Verba
                      • LoserShoes
                        • Apr 2005
                        • 524
                        • Bangor Maine
                        It can be done, but requires the correct grind on the cutting tool and a spray mist coolant. Not the kind of skills your going to find at an automotive machine shop. And in todays CNC world those skills a getting increasingly rare.
                        In the '70s one of the Cycle mags had an article about turning stainless rotors in a lathe.
                        Steve
                        80 XS1100G Standard - YammerHammer
                        73 Yamaha DT3 - DirtyHairy
                        62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
                        Norton Electra - future restore
                        CZ 400 MX'er
                        68 Ducati Scrambler
                        RC Planes and Helis
