Hi, all. I can do the conversion math to determine torque values (well, with alittle help from my son), but once I know how tight to torque a nut, I still have no idea just how to go about knowing how "torqued" it is! And, THIS torques me off!
So, if the book says "tighten to 39N.m or 28ft-lb" how do I know when I reached that degree of tightness? I thought I just rotated that old torque wrench until I couldn't get it any tighter, but apparently, that is not the way it's done.
Can someone educate me? The kid at Sears' only suggestion was that I come back tomorrow when Sam is there. . .
Cam
Cam
- NOW IT'S FOR SALE! $1,800 OBO
Examples are the cam shaft bearing cap nuts at only 7 ft/lbs, the clutch star plate bolts at 7ft/lbs. So in these situations an INCH POUND torque wrench is needed because the standard Ft/Lb ones are not sensitive enough for those low levels of torque.
