front end wobble
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    front end wobble
    Thought I would post this for the people that might have this problem also .
    When I applied my rear brake and only the rear brake at around 40 m/h or 60 km/h my front end started to wobble almost out of control . At any other speed I had no problem braking or wobble for some reason.
    Well I checked and double check everything on the front end changed the rotors , brakes pads and calibers and same results. Today I decided to check my tire pressure as I realized I could reach the ground more with me feet haha ,yes a short as@ . My rear tire pressure was low almost 10 lbs . I topped it up and the braking problem was gone no more wobbling front end.
    Pays to keep up on the maintenance.
    BDF Special
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Thanks for the tip James!
    I had poor handling complaints earlier this year and it was because of low tire pressure. Of course that was the last thing I checked.
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • NemisusDM
      • Oct 2006
      • 147
      • Carmel, NY
      Hey Guy's,
      I got rid of the death wobble by playing with tire pressure and pre-load also. For me it's 30 front and 38 rear, on my setup. I run 11 psi on the forks too. You just have to find it's sweet spot.
      1979 XS1100SF "Sakura Natsuhiboshi"
