What size??????
  • jeffe
    • Oct 2004
    • 393
    • Westerville,Ohio
    What size??????
    Quick question. I know this horse has beaten to death several times. But here goes. Stock 78E carbs, what size pod filters do I need? I know all the stuff about rejetting and everything just need to know this one thing.
    78E ... Gone but not forgotten
    2006 Kawasaki Concours....just getting to know it
    Hey Jeffe,
    CORRECTED POST! Thanks Chop for jogging my memory, I went back and did a search for my old posts....my CRS is acting up tonight! I NOW remember some previous research that I had done, the 52mm bells were on the 78E and 79F, the 79SF and later models all the way to the XJ's were 54mm. Once again we can thank Yamaha and their continuous changes to specs for this bit of confusion!
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      54mm
      54mm
      MDRNF
      79F.....Not Stock
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        pods
        I made a custom airfilter box for member oldyam80sg and he sent me the old single boots that he said kept falling off. I see why, there is two separate lip profiles on these aftermarket (non K&N) pods 54mm outter and 52mm inner. This design is cheesy and when you screw clamp them to the bells, they basically slip themselves off from the 52 to 54mm incline.....junk
        MDRNF
        79F.....Not Stock
        • 81xsproject
          • 3185
          • Fortuna, CA
          They all have the same size 54mm bells. I have measured both side by side.
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • dbeardslee
            • 4385
            • Maineville, OH
            I just put 54mm's on a 79 standard, and they fit fine. My carbs are all stamped 'E' on the bottom.
            • Montreux_Blue
              XS-XJ Guru (Deceased)
              • 1143
              Re: pods
              Mine has the cheap Emgo pods. Cleaned them a few weeks ago and noticed the same thing, they wanted to slip off when clamping them on. I had to hold the clamps forward, toward the engine, while tightening them down. Kind of a pain, but it worked.
              Famous Myspace quote:
                • 2117
                xschop-If you look at the filters you will see that they are indeed K & N.
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  no offense meant
                  These were kindly donated by Oldyam80sg and I will be trying a new chemical on them to try and soften them up. I meant that the double lip design was junk....chop
                  MDRNF
                  79F.....Not Stock
                  • jeffe
                    • Oct 2004
                    • 393
                    • Westerville,Ohio
                    So.........Will the ones from Mikes XS work ok?
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      Jeffe - the 54mm Mikes XS pods will fit. Mikes XS part #15-0035. Don't forget a breather filter and some filters for the carb vent tubes (lawn mower fuel line filters will work).
