Seat repair
  • 81 SPECIAL
    • Jul 2008
    • 8
    Seat repair
    any suggestions on the best way to repair a 3 inch tear in a seat? Other than buying a new one or redoing the seat over.
    Thanks
    If not re-doing it, there's not a lot of options. It's torn because the sun broke down the material. Trying to stitch it back together won't work... so best option really is just try to find some tape that matches "Electrical tap??" and patch it up best you can until you can spring for a new cover.
    • boyat68
      • Oct 2007
      • 358
      • Virginia
      81 SPECIAL:
      You could take the cover off of the seat, and epoxy two patches opposite the split with overlapping tongues. After the epoxy dries. bring the two ends together in a "T" and with a curved stitching needle, (Dollar store or Wall-Mart) stitch a seam through the "T", following the line of the regular stitching. This could also be done on a standard sewing machine, but with finesse. The patching material could be canvass material or thin leather.
      • Tusler
        • Jul 2008
        • 79
        • Hemet, CA
        Hi,
        Do you guys remember the stuff they use to advertise to repair rips in car seats or furniture. If I remeber correctly you put a special glue down and ironed the patch and it blended into the material around the rip.
        Check out this site, they have repair stuff.
        1980 Xs1100 MNS Sold for $1800
        2004 Roadstar XV1700
        45 to 50 MPG
        Ask Jesus for Forgiveness before it is too late!
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          I put a piece of wide tape inside the cover and make sure it was secure. Then I used some black liquid tape to fill in any gaps . When it dried I was amazed how well it turn out the colour was a perfect match .
          BDF Special
          • cruiser
            • Jul 2004
            • 393
            • Winona, Minnesota
            I've done what tusler talks about a couple times. Last on my son's Virago a couple years ago. I used the Permatex brand Vinyl & Leather repair kit. Just make sure to have a way to hold the seams together while the repair is done.
            XJ1100 Ruby Red
            XS1100LH "Midnight"
            1972 MGB Roadster "sold"
              • 2117
              I had the old seat on my SG that kept on ripping in the same spot every time.Since they stopped making the seat i took it to a upholstery shop that was cheaper in the long run.
                Hi 81,
                my seat had what appeared to be a 3" long knife cut in it's side. I got a curved upholstery needle and some black buttonhole thread and sewed the slit closed with a series of overlapping Xs. Then I dabbed the stitching with black touch-up paint. OK, up close the fix looks like a Frankenstein job but it's tidy enough and it stops the cut from spreading.
                • chrisso
                  • Jun 2008
                  • 182
                  • Sydney Australia
                  If you get your seat recovered make sure they use Marine Grade Vinyl as its twice the thickness as normal vinyl.
                  80 XS11 Standard Australia
