Middle gear box smoke ??
  • Middle gear box smoke ??
    Hey,
    I seem to solve one thing and find something new.....lol
    I have a breather filter on the middle gear box and I have that mounted under the seat. I was waiting at a red light and just happened to look down and noticed that my "goods" were smoking!!!!
    I thought it was electrical at first so, I QUICKLY dismounted and removed the seat but, found that it was comming from the breather filter while the engine is running. Is that normal???
    1979 XS1100SF "Sakura Natsuhiboshi"
    I've never noticed it but there's always a first for everything. Have you checked the oil level in the middle gear box lately?
    Ernie
      You sure that's not the crankcase vent?
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
        I was thinking the same thing, I dont believe the middle drive has a vent, but I've wrong before.
        Paul
        Paul
        1983 XJ1100 Maxim
        1979 XS1100 Standard
        1980 XS1100 Special
        I'm not a motorcycle mechanic but I play one on the internet.
          Sounds like crankcase vent to me. You can get a little smoke from that due to blowby past your rings.
          Mike Giroir
          79 XS-1100 Special
            Not smoke but a comment
            The
            middle gear has a vent in the form of a small hose ,looks like vac hose . It runs up from the middle gear and is secured near the top of the air box or there-abouts . Often I see it is mistakenly ran down along side the battery hose over the swing arm bearing housing . It can then pick up moisture and contaminate the middle gear lube . DAMHIKT
            XJ1100K
            Avon rubber
            MikesXS black coils
            Iridium plugs w/ 1k caps
            MikesXS front master
            Loud Horns (Stebel/Fiamm)
            Progressive fork springs
            CIBIE headlight reflector
            YICS Eliminator
              Smoke
              Seems to me that the nature of the crankcase vent system has the vacuum from the airbox sucking fumes up through the big hose and recycled into the carbs . My hose also produces the odd drop of oil on the air filter . Think positive crankcase ventilation(PCV) . If you have not got these parts and are running pods with a filter on the vent outlet , fume will exhaust there and may even be visible ??? Just guessing and I felt like typing ... good luck
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
                Originally posted by Axel
                The middle gear has a vent in the form of a small hose ,looks like vac hose
                On the 79's it runs up to a small bracket that is secured with the top bolt for the airbox. A lot of times, if the hose is off the bracket, it can be puzzling to figure out what the bracket is there for. The bracket also doubles to secure the part of the wiring harnes that runs past it.
                Ernie
                  Hey Guys,
                  I may have to elaborate, it's the large vent hose. I thought it was the middle gear vent.
                  Thanks,
                    Hi Nemisus,
                    Big hose is the crankcase breather. Tired motors (or very HOT motors!) will breathe a little oil fume, but even the best of engines will breathe a little steam if they have sat a while; It is just how they get rid of any condensation from the oil.
                    AlanB
                    If it ain't broke, modify it!
                      Hey AlanB,
                      It was a 90+ day and riding 2 up. It made me a bit nervous to say the least.
                      Thanks,
