PCV valve application?
  • corey
    • Mar 2005
    • 208
    • Dexter, MO
    So after having completed the pod air filter conversion three years ago, I decided it was time to finally do something with the open end of the crankcase vent tube. A trip to the local Autozone and wah-lah! A generic PCV valve on the end. It's not a little filter like I'd heard people using, but I think it will work.
    Anybody else do this before? Seems to be working fine, still have that fumey smell from the case though.. it adds to the "experience."
    Let me know if you have had any experience with this mod...
    Corey J. Bennett
    '79 XS1100SF
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    PCV
    PCV stands for Polution Control Valve, and it's basically a one way valve so be carefull how you install it. It must be able to exhaust the pressure, but on the other hand it would be nice for it to breath in also because you don't want a vacuum in there either. I wouldn't use it on mine. A little filter would be the best.
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • John
      • 5117
      PCV actually means Positive Crankcase Ventilation. It is attached to a Vacuum source on the intake manifold of an engine to draw combustion vapors out of the crankcase, and control the pressure in the crankcase.
      • DavesXS
        • Jun 2008
        • 231
        • Matthews, NC
        There will be no vacuum while running. Even with brand new rings. But I agree on not using it though. I'd stick with the little filter.
          As stated, you just have to make sure you have it installed correctly, but it is a one way valve and should work just fine. I do know of at least one other member that uses one also...
          Different strokes for different folks... More than one way to skin a Kat..
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Wouldn't plumbing the breather tube (discretely of course) to one of the filters be a good way to go? Maybe a small manifold (aquarium?) that would plumb the main tube to 4 smaller tubes and run those to the 4 nipples we use to sync the carbs.
            On Wifes XS750 (sold a couple of years ago) I installed a chrome airfilter box. I installed the 1 into 3 plastic tube the OEM airbox had into the chrome "pod" and hooked the breather tube to that. This way the vapors were burned in the engine as originally intended.
            Looked good too.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • geniusloerts
              • Jul 2007
              • 420
              • fayetteville, Arkansas
              i run a breather filter on mine
              1979 XS1100 SF "Black Goblin"
              -Pod Filters
              -4-1 pipe
              -larger jets for carbs
              1982 XJ1100 "Black Sheep"
                That would cause some lean conditions letting those suck at those points. You could eventually tune for the different air AMOUNT, but the fuel and air get mixed in the carbs, and that would create a stream of just air into the mix.
                If you could plumb the line in before the carbs to the filters somehow, that would be the best option, but you'd want to get it to all four somewhat equally, not just one.
                • blue giant
                  • Aug 2007
                  • 880
                  • Ontario, Canada
                  If the PCV valve is indeed a one way valve would it not be possible to create a vacuum in the crankcase when the hot engine cools?
                  JAT
                  Paul
                  Paul
                  1983 XJ1100 Maxim
                  1979 XS1100 Standard
                  1980 XS1100 Special
                  I'm not a motorcycle mechanic but I play one on the internet.
                    No...
                    Although a piston flying up and down in the cylinder will make compression, there are gaps in the rings that let pressure by. That's why you can hand crank a motor over failry easy. It won't build the pressure up since it slips by the rings. Same thing if there were vacuum built up slowly as the motor cools... it would find a cylinder with an open valve and draw in what it needs.
                    BUT... this does lead to another "What if"....
                    PCV valves can get clogged over time. If it got totally clogged, it could get XS pressures built up inside the crankcase... causing???? Blown gaskets?? Oil coming out of strange places?? No telling... just something that you better keep an eye on.
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      When I had the PVC intake extenders on my bike (before I got the Mikesxs K&N replicas) I had considered plumbing the vents into the extenders. Folks talked me out of it though and I am glad. I have my carbs on and off too much for additional things to disconnect.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
