Crank case pressure?
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Did an oil change tonight and ran the engine with the oil fill cap off. Is it normal to have air blowing back out of the fill hole?
    I did a search but didn't really find an answer.
    Thanks,
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • 2117
    I would think so.I have a K & N crankcase breather and it does breathe.I can see something coming out!
    • The Lorax
      • Jun 2005
      • 1048
      • Riverside, OH
      I've seen leaving the oil cap off in a car make a real mess. been a few years since I saw it, if I remember correctly, after a twenty minute drive, the entire underside of the hood was dripping with oil. doesn't really surprise me that it would shoot back out. in fact, I had a 1990 Volvo 740 turbo a while back and when I got it, the seal on the filler cap was bad, is routinely dumped oil all over the top of the engine....that was just with a bad seal on the cap. that's all I got, have a nice day and ride safe
      I am the Lorax, I speak for the Trees
      '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
      '79 XS1100 F R (IL Barrachino)
      '00 Suzuki Intruder 1400 (La Soccola)
      '77 KZ400s (La Putana)
      • olebiker
        • Aug 2007
        • 692
        • Kingston ON
        Paul yes it is. There is quite a lot of air movement.
        http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
        • egsols
          • Jan 2006
          • 1090
          • Barrie, Ontario, Canada
          Yes, as the pistons move up and down the air must be displaced in the crankcase somehow. Also, as the rings wear, you will also get a certain amount of blow by entering the case.
          Why???
          Ernie
          • blue giant
            • Aug 2007
            • 880
            • Ontario, Canada
            Ernie,
            Did it more by accident than on purpose. It was just when I was idling up to temperature.
            I also have a very predominent tick in the top end. Sounds like its in the valve train but its hard to pinpoint. It's more pronounced on the right side than on the left.
            Paul
            1983 XJ1100 Maxim
            1980 XS1100 Special
            • Erik the Red
              • 422
              • Northern MI
              I'm not disagreeing -just adding...
              Originally posted by The Lorax
              I've seen leaving the oil cap off in a car make a real mess. ...entire underside of the hood was dripping with oil. ...routinely dumped oil all over the top of the engine....that was just with a bad seal on the cap.
              I had an '84 Olds Delta 88 in college. Changed the oil at a friend's house since I was in the dorms. One oil change I went to remove the cap and it wasn't there. I looked and there it was sitting on the window sill ....from the last time I changed the oil. I'd been running for 3-4 months with no cap, and didn't have a problem. It was probably a good thing it was wintertime.
              -Do what makes you happy.
              '79 Honda CB 750 K (2)
              '78 XS 11 E - "Rhona"
              ...and a 2nd E, for the goodies on it.
              • egsols
                • Jan 2006
                • 1090
                Originally post by Blue giant
                I also have a very predominent tick in the top end............It's more pronounced on the right side than on the left.
                You may want to seek immediate medical attention for that, I think there are some new medications out there that may help.
                Ernie
                • blue giant
                  • Aug 2007
                  • 880
                  • Ontario, Canada
                  Too funny Ernie!
                  Paul
                  1983 XJ1100 Maxim
                  1980 XS1100 Special
                  • petejw
                    • 2269
                    • sydney australia
                    blue giant.
                    "I also have a very predominent tick in the top end. Sounds like its in the valve train but its hard to pinpoint. It's more pronounced on the right side than on the left."
                    I have that tic 2 on the right hand side as well, was still there after i had the head fully serviced. very annoying.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • blue giant
                      • Aug 2007
                      • 880
                      • Ontario, Canada
                      Pete,
                      When I searched the site for similar problem posts I found one where the owner did just about everything to find and stop the tick and ended up swapping the head out for a used one. No more tick!
                      I'll check what I can to make sure I'm not going to trash the engine. This might be this winter's project.
                      Paul
                      Paul
                      1983 XJ1100 Maxim
                      1980 XS1100 Special
                      • blue giant
                        • Aug 2007
                        • 880
                        • Ontario, Canada
                        Pete!
                        Here the link to that thread.
                        Top End tick
                        Cheers,
                        Paul
                        Paul
                        1983 XJ1100 Maxim
                        1980 XS1100 Special
                          Have you checked the exhaust gaskets? Mine developed a tick a few weeks ago, and I discovered a couple of loose header nuts
                          • olebiker
                            • Aug 2007
                            • 692
                            • Kingston ON
                            As you know Paul I just did the head on mine (twice ): ) and now new cam chain valves all set right. The thing is still noisy I believe it is just a damn noisy engine. I also have a bigger windshield on this one and maybe it is reflecting more of the noise back at me.
                            • petejw
                              • 2269
                              • sydney australia
                              hi Paul,
                              thanx for the link,
                              ill recheck the exhaust flange nuts, its been a while.
                              i did have the head fully serviced, and its quiet wen its cold
                              starts ticking after it warms up, been this way 4 a few years
                              so im not 2 fussed about it.
                              good luck with urs.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
