Can oil weight affect gas mileage?
Oil weight and gas mileage
Tags: None
yeah, at least a little bit. I've heard thats part of the reason all the auto manufacturers are now recommending 5w30 or 0w30 in new cars instead of 10w30 like they used to.1979 xs1100 Special -
My Bike:Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken] -
heck ford is big on 5w2081 SH for 300 bucks,work in progress.
87 dodge d-50,35's,lockers fr&rr,fun.
87 dodge d-50,35's,open diffs,wifes.
89 dodge spirit,low 17's 1/4mile w/o turbo.Comment
The nascar dudes put a very light weight oil in to qualify. Light weight oil, less drag; less drag, better mileage. (and top speed) For the rest of us though I think it would be splitting hairs. I can't imagine any substantive improvement in gas mileage that would warrant the extra risk to the engine's longevity.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fixComment
Reason im asking is i was runing 15w40 and went to a 20w50 and i went from about 30 down to 24 I am thinking of going to syntheticComment
I'm having a hard time believing that oil would make 6 mpg of a difference - but then I've never tried it either. Interesting.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
I'm no expert but synthetic might cause problems with your clutch.
I recently, by accident, put 5w20 in mine. I realized my mistake when all the mosquitos started to die off.
BTW I used to run Rotella 15W40 in my other 79, now I'm running Castrol 20W50 on my new 79. The new 79 does get way better mileage than the old but that could be due to having the carbs set up better. Not really sure.Ernie
(Improving with age, the bike that is)Comment
Oil
Im not running an XS any more but i do run Amsiol motorcycle oil i found it shifts smother runs cooler , last longer and no probs with the clutch but thats just what i have found. your results may vary!I now change my oil every 6000 miles and the oil looks as clean as when i changed it. but its very expensive at 10 dollars a liter.
DougDoug Mitchell
82 XJ1100 sold
2007 Stratoliner 1900 sold
47 years riding and still learning, does that make me a slow learner?Comment
Hey Tired,
I remember reading about a few folks who went from 10-40 to 20-50 and they started to experience clutch slippage! I don't recall if it was Synth or Dino based, but the thicker oils are a bit more slippery, and even though you might not be able to sense any rpm rise at a certain MPH, but it could be slipping a little. The 20-50 range means that it's supposed be able to have the thinness of 20 weight , especially in cold weather, but has the breakdown resistance of the 50 weight!! So..I wouldn't think that it's causing too much resistance with the crank sloshing thru the pan!
Haven't used Amsoil, but have heard good things about it, but ANY oil has the potential for aggravating a marginal grabbing clutch!?
T.C.T. C. Gresham
Amsoil
i use Amsoil 20W50 syn in mine and have no problems with the clutch even dropped the head temp when idiling.
John
PS dont want to start another Oil war LOL79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
80 XS1100 S Project gonna be a hot rod
06 CBR1000RR sold!!!!!
2000 Concours
84 Kawi KLR600
79 Yam XT500 Ouch it kicks back
79 XR250
Why is it that the smallest part can fly to the farthest part of the shop?
JohnComment
