Mystery Machine
  • gixxer
    • Jun 2008
    • 27
    • Eastern Canada
    Mystery Machine
    Can anyone tell me by looking at these pics what model XS this is?
    '81 XS1100 H
    Special Tank
    Special Headlight
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    I'll take the first shot at it and say 1980 XS1100 Special.
    I'm sure the guru's will be along shortly!
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    • olebiker
      • Aug 2007
      • 692
      • Kingston ON
      The fender is off something else but it sure looks like my 80 special.
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
      • gixxer
        • Jun 2008
        • 27
        • Eastern Canada
        A couple of details for you that you can't tell from the pics. It has a 17" rear wheel. The original speedo and tach are missing so don't know if they were round or square.
        '81 XS1100 H
        Special Tank
        Special Headlight
          Look at the slope of the top of the right side cover. That would be an 80-81 Special.
          • xswilly
            • Jul 2003
            • 462
            • Hollis, maine
            the kick starter is plugged off
            so it is not a 78 or 79
            slotted rotors also puts it into a 80 or 81
            http://home.securespeed.us/~xswilly/
            78E main ride, since birth the "good"
            78E Parts, the "bad" fixing up now
            78E Parts the "ugly" maybe next year
            79F Parts
            80G Parts
            75 DT 400B enduro
            • XSPastor
              • Oct 2007
              • 602
              • Gaithersburg, MD
              An 81 special if that's the original alternator cover. The 80 didn't have the circle around the Yamaha. There are definitely many alterations. That may not even be the original engine... The only way to tell on a bike like this would be the vin number.
              Tim Ripley - Gaithersburg, MD
              23mm float height
              120 main jets
              42.5 pilot jets
              drilled stock airbox with K&N
              Jardine 4 to 1 Exhaust
              spade fusebox
              1st and 2nd gear fix
              • SFerinTEXAS
                • Jun 2006
                • 877
                Forks are from a standard
                79SF
                XJ11
                78E
                • olebiker
                  • Aug 2007
                  • 692
                  • Kingston ON
                  That might account for the fender.
                  • XSPastor
                    • Oct 2007
                    • 602
                    • Gaithersburg, MD
                    How could the forks be standard if the brakes are special?
                    23mm float height
                    120 main jets
                    42.5 pilot jets
                    spade fusebox
                    • SFerinTEXAS
                      • Jun 2006
                      • 877
                      Brakes are standard
                      79SF
                      XJ11
                      78E
                      • XSPastor
                        • Oct 2007
                        • 602
                        • Gaithersburg, MD
                        Ahhhh...
                        23mm float height
                        120 main jets
                        42.5 pilot jets
                        spade fusebox
                        • GNEPIG
                          • Apr 2005
                          • 1656
                          • fl
                          Looks like it's mostly a Standard with a Special tank, but I can't really get a good look at the frame.
                          Groovy lookin way to change the Spaghetti exhaust. Not very good for cornering clearance tho.
                          • geniusloerts
                            • Jul 2007
                            • 420
                            • fayetteville, Arkansas
                            i would say it is a special with a standard front end........seat is obviously custom and rear fender may have been changed.
                            1979 XS1100 SF "Black Goblin"
                            -Pod Filters
                            -4-1 pipe
                            -larger jets for carbs
                            1982 XJ1100 "Black Sheep"
                            • gixxer
                              • Jun 2008
                              • 27
                              • Eastern Canada
                              Thanks for your input guys. You see my dilemma. I want a new seat and misc other things but I don't know what will fit. Can anyone tell by looking if I should get a std or spc seat?
                              '81 XS1100 H
                              Special Tank
                              Special Headlight
