need throttle cable for xj if any has a spare pm me.
throttle cable needed
http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
That throttle cable won't fit the XJ....
Most bike shops can order one for you, but are higher than that. Cheapest one I found was @ $30, but you may have better luck. There is a plastic adjuster on the end that goes up into your throttle grip. Make sure this isn't broken when you buy it. I went to a shop that had three of them on the wall, but all three had that plastic part broken.
Nineteen bucks at this site.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
