YICS Question
  • Rhumba
    • 82
    • Vancouver, WA
    YICS Question
    I haven't had to synch my carbs yet as the bike is running very well, however I am interested in the process for when the time comes.
    In reading the YICS tool how-to I noticed that the YICS was described as a passage that all 4 carbs share to increase vacuum efficiency. If the carbs are connected by this vacuum passage, wouldn't that equalize tiny differences between the carbs vacuum settings, rendering syncronization moot?
    Just a thought...set me straight
    Never scratch your head with a nail gun!
    1982 XJ1100
    Yeah, that's what it does, sort of. And it will try to do it when the four carbs are all at quite different settings. Imagine that you've got one butterfly open way too far compared to the others, then the YICS gallery evens out the vacuum, and hence the flow through the venturi. Now you've got an airflow through the venturi that doesn't match what what another carb would do at that same butterfly opening.
    That's why you want to isolate the four carbs first, then use a vacuum sync tool to get all four butterflies exactly the same. Then you can reactivate the YICS system and let it help by smoothing out the vacuum pulses.
    That's how I understand it. Anybody with some real carb knowledge want to add something more or different?
    • ross
      • Dec 2006
      • 542
      • see signature...
      yics tool....
      hey there folks...i have seen the tool and the owner explained how it works....i think ken has it right.....but ya need the tool to sync the carbs......no other way.....ya might wanna check with the guys on the xj site.....if ya can't find it, let me know....the guy i know goes by schmeerman on here, but he seems to be very good with the xj's.....i have his # (i think) if ya need.....let me know....ross
      rebel devil
      1979 xs 1100f standard
      authenic historical vehicle
      42°36'23.52"N, 82°52'44.78"W
      "I'M IN MY HAPPY PLACE"
      "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
      "if you don't wrench on it, get behind me satan!"
      '96 venture cct.....installed!
      stainless, braided, pvc coated brake lines
      i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Check out this thread.
        DIY YICS tool
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
        • ross
          • Dec 2006
          • 542
          • see signature...
          hey there xspastor....don't mean to step on your bosses toes, but that is a sync tool.....a yics tool fits into the engine and has a flip lever that shuts off the ports to each carb.....btw, gave you a shout out in the "an irish perspective" thread.....hope ya like....talk 2 ya later...ross
          rebel devil
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            You're absolutely right, Ross. I pasted that link in based on the title. I didn't even look at the thread which is - as you said - all about sync - not the YICS tool. This is the one I was thinking of:
            do it yourself YICS tool
            Thanks for pointing out the error.
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
