I am asking for support once again. I am still having a problem getting my carbs working the way they should. I have disassembled the carbs and soaked them in a carb solution and cleaned them very carefully. I adjusted the float with a depth mike and tested the fuel level with a plastic see thru hose. I took my time and I think it was set as precise as possible. I did not install new needles and seats. I think I should have. I reinstalled the carbs on the bike. The bike started OK and seemed like everything was working well however for some reason the RPM's started increase rapidly and erratic. It did idle OK long enough for me to synk the carbs with mercury. I am getting to be an expert who doesnt know what hes doing. I am thinking the needle valve (float) is staying open.
If anyone can steer me in a direction that will help solve this problem I would appreciate it.
My bike is XS1100H Venture.
