Shim argument
  • SiP
    • 438
    • Medicine Hat, Canada
    Shim argument
    I basically have two questions, there's a big argument going on here in my shop regarding the second one.
    1. How often do you need to check the valve clearance and hence the shims?
    2. In my experience (XS1100) the shim method of setting valve clearance is very reliable and lasts for a considerable amount of time / miles. Am I correct in saying this?
    IMHO it's: Hydraulic; Shim; set nut - in order from best to worst.
    This has arisen from my buddies dirt bike. It's an 05, he hasn't ridden that much (no more than 30 days in a year), and he thinks his clearance needs doing.
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
  • randy
    • Dec 2003
    • 4521
    First off, if your buddy's bike is a two-stroke, his valve clearances will last forever!
    In my experience you are correct.
    • DavesXS
      • Jun 2008
      • 231
      • Matthews, NC
      Your buddy with the 05 he thinks needs shimmed, might need to adjust cam chain tensioner(if they even have one). I'd imagine a new bike would need adjusted after the break in period.
      Mine has 38k and you barely here any valve noise. I doubt the po shimmed because the 2 past PO's were idiots. I might think about shims after 50k.
      But I have limited experience in this matter.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        you are correct with that order... hydraulic, shim and then set/nut.
        shims are very reliable and really, judging from some of the other bikes i've worked on, less of a hassle.
        i'd have to look at a maints schedule, but we adjust our valves no more than any other style. valves losing clearance over time is normal and has nothing to do with which adjustment method they have.
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          The Manual says to check the valves every 9600.00 KM (6000.00 miles)...
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
