question for gurus
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    question for gurus
    bike has been starting good
    haven't run it in awhile as other things have kept me busy
    so today i took it out, to get it ready for the safty inspection ( required by the state )
    started fine, rode around the yard fine.
    pulled into the driveway, parked it in the sun,
    washed it, sprayed it good with the hose.
    now it started right up, just as always.
    but when i put it into gear it dies,
    tried everything, put in gear not running and try to start-nope
    kick stand up or down no difference.
    its a 78E there is no safty switch at all never was.
    i'm letting it dry out now
    but it has been an hour and same thing
    on the centerstand
    starts right up
    drop in in gear and it dies, right away just like shutting off a switch
    any ideas, on what to look for
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    wet
    Happens quite often.
    It should dry out and be ok.
    I have had this a couple of times, can't track it down, but the neutral switch is involved.
    But, I am no guru so: YMMV
    XS1100SF
    XS1100F
    • xswilly
      • Jul 2003
      • 462
      • Hollis, maine
      thanks for the answer
      you were correct
      i washed the bike around noon
      i checked it at 6 pm, nothing
      i just got home tonight 9:30
      before i went into the house i checked it
      and it started and shifted ok
      next time, no garden hose
      79F Parts
      80G Parts
      75 DT 400B enduro
