Cam Chain Tool
  • AustinPhoenix
    • Mar 2008
    • 112
    • Austin, TX
    Cam Chain Tool
    I will be replacing my cam chain soon and wanted to know if there was a suitable tool or "rig" to break and link the chain aside from the $85 tool.
    From the look of it, a small vice looks like it will work, but I'm just asking around. Thanks!
    1980 XS11g Standard - "Ash"
    4 to 2 Exhaust
    K&N Pod Filters
    Fuel Filters
    Inline shut off valves
    Slotted Rotors
    My heart and soul
    Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
    1979 Special Project Bike
    Non-gasoline conversion
    cam chain tool
    Mikesxs.com has a $35 cam chain tool that works just fine.
    • AustinPhoenix
      • Mar 2008
      • 112
      • Austin, TX
      Oh wow...
      I only looked at Partsnmore and z1enterprises. Thanks phil!
      4 to 2 Exhaust
      K&N Pod Filters
      Fuel Filters
      Slotted Rotors
      My heart and soul
        Dremmel tool with a cut-off disk.
          Like Skids said... but you can use any grinder to cut it... just drop a cloth over what you can on the head to keep the metal shavings out as much as possible. I used a 4 inch grinder on mine.
          The replacement chain's final master link will have a pin that is hollow. After inserting the final link onto the chain and attaching with the pin, just use a center punch to peen out the edges of that hollow pin to keep it from sliding back out.
          The special tools are nice to have, but definately not needed.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Go to a bicycle shop and get a chain tool there, $10.
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • AustinPhoenix
              • Mar 2008
              • 112
              • Austin, TX
              No way
              Pat...will the same chain tool used on my Huffy work on my XS?! You have got to be kidding me. Really?!
              4 to 2 Exhaust
              K&N Pod Filters
              Fuel Filters
              Slotted Rotors
              My heart and soul
              • Pat Kelly
                • 3046
                • Golden Valley, AZ
                Worked for me
                Pat Kelly
                • scalded dog
                  • 458
                  Just bought a cam chain and a valve cover gasket tonight off e-bay, not sure if I needed it, but this noise I hear has gotten worse, don't sound like a valve or a rod, no loss of power just this tinny noise thats aggravating, it's loudest when cruising around 65 mph, is there another way to check to see if the chain is bad? Thanks 'Dog
                    Have you done a chain adjustment?
                    • scalded dog
                      • 458
                      Trbig, thanks for the reply, I have adjusted the cam chain periodical, over the last 65,000 miles, the bike had 12,000 on it when I bought it, I've noticed that a lot of the bikes need this replacement around this mileage or sooner. Thanks 'Dog
