1979 xs 1100sf, 45ks
ran perfect up until lately: as i ride along suddenly it loses power as if no fuel in a couple of cylinders. at standstill and idle i purrs along fine; whipping the throttle wide open the engine responds flawlessly.
i disassembled the carb, inspected EVERYTHING on it; checked plugs, air leaks, connections, timing e.t.c. lately, i discovered when i throttle up to around 2-3k and hold the throttle there the engine oscillates; in other words it simulates a constant throttling up and down, but without me doing so!!!!
So, what is up with that?? i am pretty experienced with these machines: I two indetical xs1100s and '72 honda 450. I know my stuff. there are a few more things i want to try, however, one of you may have quicker idea-- help me out guys
THANKS
THANKS
. also, check your petcocks and fuel delivery as well, if one of the lines is kinked, it might starve one bank of fuel giving you the 2 cylinders losing fuel symptom. just a thought.
