As some of you may have read, I was working on a head gasket replacement. I had everything going pretty well or so I thought.
Last night, I finally got it all back together, new head gasket, yet another new valve cover gasket, scrubbed the oil off my exhaust pipes and remounted them.
Then the moment of truth. I advised my neighbors that if it didn't start up and run right, go inside and lock the doors and windows.
So I turned the key, hit the start, the engine turned for a second, then...tap, tap, tap, a loud metalic sound coming from the left side of the engine, probably upper left but I didn't keep trying it as I was afraid of causing more damage. Once the tapping sound started, the engine was no longer turning over.
OK, no sugarcoating....how bad did I screw something up? I tried hard to follow along with my repair book. I'm suspecting a rocker arm or something. Again, I am a novice mechanic. The only reason I suspect rocker arm is that one broke on a large engine for a speedboat I was running years ago and I remember that sound. Seems to me roughly the same however with that boat, the engine ran, just had a very loud tapping so I secured it ASAP.
Any chance it's something else...please say it is something simple? Oh that's right, I asked for no sugarcoating. Damn!
Don
Don
