forever neutral
  • Filter
  • forever neutral
    No engagement.....
    so i fixed my clutch cable, everything fine.......took off headed back to work and i had to stop on a hill for trafic, down shifted into 1st and went to go and had no engagement......it is stuck in neutral....
    i think the shift fork thing that looks like a hand with fingers disengaged...what do you guys think?
    I already had problems with first hear hoping or slipping inder acceleration......
    HELP!!!
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
  • #2
    First would pull the shift cover. Wet cover so either drain oil or lean bike to right same amount as kick stand holds bike to the left.
    Check the shift lever is still engaged on shift cam.
    If all is good then might need to pull engine.
    mro
    • #3
      Pulled the shift cover off
      ok so here are the results
      Shift lever is gripping shaft
      the little hook that pulls/pushes the shift cam does not grab it...
      I found 5 pins in the oil that drained out.......
      looks bad for me
      where to go from here?
      -Pod Filters
      -4-1 pipe
      • #4
        5 pins
        Don't remember how many...but sounds like they may be shift cam dowl pins. Think there just under 1/4" dia and less than 1/2" long.
        mro
        • #5
          they are just over .5" and probaly 1/8-1/16 in diameter
          -Pod Filters
          -4-1 pipe
          • #6
            have a look see
            The "fingers" and shift lever
            and the pins that came out in the oil.
            -Pod Filters
            -4-1 pipe
            • #7
              Hmm pics.
              Deleted my post till I look em over.
              mro
              • #8
                Hey Genius,
                That's good, a simple fix. The Plate on the end of the shift drum that holds the pins in place can and apparently DID get bent, allowing the pins to fall out. DON'T try just bending the plate back, once it's bent, it looses its strength. YOu can order a NEW ONE From Yamaha, any source you like, and you'll be good to go after that!!
                • #9
                  from what i can tell on the yamaha fiche sheet pictures online those pins hold on the plates or hold them in place or something
                  not sure really
                  -Pod Filters
                  -4-1 pipe
                  • #10
                    TC,
                    that is a releif
                    i wil get right on that
                    -Pod Filters
                    -4-1 pipe
                    • #11
                      ok, so i just went back out and looked to see if i could see where those pins go and i am not sure........... it looks like the shaft that the shift fork bar guide is sticking out too far as well so the shift lever does not grab the shift cam
                      -Pod Filters
                      -4-1 pipe
                      • #12
                        look at this
                        ok it apears the shift fork shaft sticks out about 1/4" which keeps the shift lever from engaging the shift cam lobes.
                        -Pod Filters
                        -4-1 pipe
                        • #13
                          trouble areas?
                          look at this one.... a little eaiser to see
                          -Pod Filters
                          -4-1 pipe
                          • #14
                            Hi, Genius ...
                            MRO has sent me those pics once upon a time .... the ones that he's looking for now ... were very helpful .... can't remember if I returned 'em ... lol ... I think you could search on 'shift cam' and find 'em ... I've done this job a number of times since then ... too many projects have I ... lol.
                            What you have circled appears to be the hook that catches the pins that rotate the shift cam that moves the trans back and forth through the gears. Like TC says, flatten the lock washer, unscrew that little 8mm headed bolt and take the stuff off the end of off the shift cam. Then you will clearly see the five little holes where those loose pins came from. Order a new pin washer, cuz yours is history, or maybe even two (who knows how much longer they'll be available?) from your dealer for about 8 bucks ... new bearings are 5 to 8 bucks if one is missing or shows signs of adverse wear... there are two or more different sizes on there, IIRC.
                            Don't forget to align the dots on the shift shaft and shift lever cogs and properly load the big spring. There is an eccentric bolt that can be turned to align the hash marks on the shift cam and shift lever ... do that with the trans in second ... that 'fine tunes' the shifter throw. Stick it back together, check yer oil and for leaks ... and take 'er for a spin. ... and, yes ... there is no 6th gear on this model ...
                            80G Mini-bagger
                            Past XS11s
                            • #15
                              i sure do wish it did have a 6th gear........that would make me supper happy. i could keep with the new bikes on top speed.
                              I guess i was thinking i would be able to see where the pins came out from or the plate that was bent, but if it is behind the shift cam sproket that makes since, but i still dont understand how they can come out.....oh well, it is one of those thing i will probably never understand in this life, just like why we can't have automatic weapons. I will figure it out.
                              -Pod Filters
                              -4-1 pipe
