plug wire change
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    plug wire change
    O.K heres what i did.... followed the wire change info posted on this site [milled out the coil put wire in and rtv'd etc] all went quite well, but could not get wires like is explained on this site, so just bought auto wires and used them.
    before i dismantled the old coil/wire the resistance on 1/4 was 23 ohms. across 2/3 it was 15 like it should. [btw, i suspected wire 4as this is where i got zapped] . any way...after the new auto wires were installed i read 22k ohms across 1/4 and 2/3. at least they were consistent. pretty needless to say it don't work. will fire but not run. so...any info or links to sites with the rite wires and or plugs would be appreciated. so far $16 pissed away on auto wires. this is an 80 midnite 1100
    thanx in advance.
    redbone
    testing 1-2-3
    1980 1100 mns
  • randy
    • Dec 2003
    • 4521
    redbone,
    you need to use wire with a stranded metal core, not the resistor core that OEM auto wires are made of. ACCEL is one brand, there are other off-brands, you can get them on Ebay, too. If you can find an S&K Speed shop near you, they sell it by the foot, cut off the roll.
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      wires
      I have been using 8mm NON solid-wire wires without resistors along with the Dyna coils for 3 years now with No problems....what's the big deal with the solid wire? I could care less about someones radio reception (cap resistors were FCC propaganda)
      MDRNF
      79F.....Not Stock
      • mro
        • 4276
        • Hayward, California
        Check ballist resistor
        mro
        • GNEPIG
          • Apr 2005
          • 1656
          • fl
          What plug caps did you put on? If you use resistor caps and resistor wire= that would cause too much resistance.
          If your caps are nonresistance (less than 1 ohm) already, then try removing the ballist resistor and see what happens.
          • Da-Bubble
            • Jun 2006
            • 353
            • Oklahoma City, OK
            If you can't figure it out, the high output coils from MikesXS work great and are cheap compared to the Dyna or Accel coils. You CAN use the auto style wires with them.
            1979 XS11 Special (slightly modified)
            dubbed the "Mad Mosquito"
            MikesXs Pod Filters
            MikesXs 35k Coils
            8mm plug wires
            42.5 Pilots 142.5 Mains
            (Carb tune by GNEPIG Performance)
            Kerker 4-into-1
            Shaved emblems
            Progressive frt springs lowered 1.5"
            Progressive 11.5" rear shocks
            Harley Dyna rear fender chopped
            Custm side mt tag (apparently illegal)
            Custom Dual Headlights
            Lots of time and hard work.
            • Bigleo
              • 93
              • Surrey BC Canada
              MRO is correct. If it will fire but not run, the ballast resister is probably toast. The ballast resistor is bypassed when the engine is cranked for maximum starting voltage, but once the starter is released, all voltage to the coils goes through the resistor. If it is defective, no voltage to the coils.
              Leo
              1980 XS1100 Special
              1197cc Wiseco kit
              1978 cams
              4 into 1 Jardine with glasspack
              Keihin CR33 mm carbs
              K&N individual pod filters
              TKAT fork brace
              • randy
                • Dec 2003
                • 4521
                If the ballast resistor is toast, and you bypass it and it works, that's good. Just don't run it that way for any length of time or the TCI will be damaged. Get a replacement resistor before you put it on the road.
