Brake Light Problem
  • FSCGunslinger
    • 200
    • Hedgesville, WV
    Brake Light Problem
    My bro-in-law shot me an email today. Here's what he has to say:
    The problem is that we've got no brake lights. Running lights are good but they don't change with brake application. First things first, I erred on the obvious side and replaced the bulbs (figuring I was lucky enough to have both brake filaments blown...) but that didn't handle it. I'm imagining its now something to do with a brake solenoid or a switch along the way. If it was only the front or rear brake I'd look more specifically at the switches near the handle and/or foot lever but with neither affecting the brake light, I'm thinking it is a switch or solenoid somewhere mid-system. Can you have your gurus pick my story apart, tell me how stupid I am, and then maybe if they are feeling generous, point me in the right direction for testing the components along the way?
    So any ideas, fellas? This is for my XJ.
    "I said I never had much use for [a pistol], never said I didn't know how to use one."
    '82 Maxim XJ1100J (Maroon) - "Organ Donor" - Parts bike
    '82 Maxim XJ1100J (Black) - "Outrider" - Dynojet Stage 1 kit, Kerker 4-1 exhaust, AGM battery, Mikes XS coils, small inline fuel filters, Dunlopp Elite-3 tires
    '06 Star Warrior (Custom Gadsden Flag Theme) - "ΜΟΛΩΝ ΛΑΒΕ" - Sissy bar w/ luggage rack, 4" risers, braided stainless steel cables and brake line; Mods on deck: new exhaust, new seat
  • mro
    • 4276
    • Hayward, California
    First would check the rear brake switch.
    Has been known to stick and brake light stays on.
    Clean/check electrical connectors
    If wiring is same as an SH...
    At the rear, the 6 prong connector, the yellow wire is for brake light. Test with multimeter if you get 12V there when applying a brake. If you have 12V there then sounds like you have a ground problem.
    If no voltage then there's an open or both switches be bad.
    Will need to check wires for a break.
    mro
