K&L pilot fuel jets
  • K&L pilot fuel jets
    Well, you were all right. Those K&L rebuild kit pilot jets were too big. I got new 42.5 pilots from Dennis Kirk and the it instantly idles better. Doesn't carbon up the plugs anymore. I just get a occasional spit back through the pilot air jets in the first 1/4 throttle. Don't know what's going on there. Could probably use new plugs after carboning up so many times. I never would have figured out any of this without all the carb info I've found on this website and the help from those who replied to my threads.
    Ken Sissom
    the spit back you refer to is a classic symptom of slightly lean running off idle,try a colourtune on your idle mixture. i wouldnt say its too serious tho,unless it happens all the time,is it mostly when engine is cold?
    mick
    xs1.1s(x2)
    gsxr1100(1127)
    gsx1100g(x2)
    trophy900
    bonneville750
    http://www.tonyfoale.com/
      Gonna play some more with it today. Gotta go get some insurance and get her registered. Last night it was all warmed up (big fan blowing in front of engine)and was spitting back thru the pilot air jet occasionally as it came off idle just as you said. Wasn't all the time. Right now i just glad I didn't give up and sell it last year.
      Ken Sissom
        I keep hearing everyone talking about this "colortune". Is this something like a mercury gauge or something different. I have just put on pods and my plugs were already getting black after about 4 hours of riding time. I like to have everything just right so me and the SO are not stranded any where like we were with my 750 special. Which would be better, a Colortune or a merc gauge?
        Jason.
          Colortune is a tool to check fuel mixture, ie rich or lean. A mercury guage is for sync. carbs. Check this link about Colortune.
          http://rdent.com/pages/tools.html
          Gary
          79sf
          78e
            I got a color tune this winter. Can't say bad things about it but good?
            My carbs probly need rebuilt but the color tune won't change colors like it should no matter how i try to adjust the needles.
            still haven't given up
            ACE
              I think it is important to get the vacuum equalized at idle (synchronized with mercury stix) before you mess with the colortune. The vacuum synch adjustment adjusts the throttle plates (butterflies) relative to one another and exposes the pilot circuit pinholes in the ventouri tunnel more-or-less in that process. You can imagine how the synch process could affect the mixture. The pilot screw only adjusts one of four pinholes in the pilot circuit.
              [QUOTE]Originally posted by ACE
                She be back on the road. Insurance through Progressive was only $75.00 for 12 months. Everyone else I called was twice as much. The plates here in Nevade tripled in cost since the last time I had in registered which I guess was back in '98. I road around for roughly 25 miles and I didn't notice any spitting after it was up to full operating temp. That colortune thing looks interesting. I assume that it's only used to set the idle mixture. And I assume if I get one of these things that I would need to get the "motorcycle colortune" version.
                Ken Sissom
                  Colortune
                  Colortune helps you set the pilot mixture for revs up to 4000rpm.
                  This is where a lot of driving is done . Hence idle circuit is not just for your 1100rpm idle . I find it most necessary . Sync first to get it close. Colortune and sync again. So a sync tool is key . I like the Morgan Carbtune. I was using my friends colortune but wanted my own and ordered one from eBay .
                  http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=260252980039
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  Iridium plugs w/ 1k caps
                  MikesXS front master
                  Loud Horns (Stebel/Fiamm)
                  Progressive fork springs
                  CIBIE headlight reflector
                  YICS Eliminator
                    Axel how long did it take to get that delivered?
                    http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                      Royal airmail
                      I'll let you know when I get it . Part of the extra shipping cost is for Royal Mail Airsure so we'll see how quick that is.
                      XJ1100K
                      Avon rubber
                      MikesXS black coils
                      YICS Eliminator
                        Thanks.
                        • #13
                          Different number of colortune
                          It takes about 10 days to deliver . The colortune I received was for cars and not the motorcycle specific one . My friend says it will work so I'm off to play with it tomorrow .
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
                          • #14
                            That is as quick as some of the stuff I buy online from North America.
                            • #15
                              Shipping
                              Agreed . Cheaper shipping and no duty . Somebody doesnt want us doing business cross border and everyone else is getting rich from it .
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
