I just put in the ingnition switch so maybe I will no overcharge the battery. But I seem to have lost my headlight all together. There are some wires that are cutand capped off before I lost the headlight ot sure where they went. I have the wiring diagram but don't know how to read it and aso have no experiance in wireing. I need to get up and running to cut cost on gas any help would be appreaciated.
Ok Here is what I see
2 blue wires hooked together on the same side of a connector that go to nothing.
green/yellow and brown wire that are wraped together cut 2 inches after their connections
I took the connections apart and tried to clean them and put them bak together before undoing the next connection. I went through the whole bike. changed the reserve lighting. checked all the fuses. cleaned the grounds. What am I missing?
All the other lights work but no headlight high or low. I evern changed the bulb.
thanks
thanks
