Vacuum Tuning
  • Dragon Tamer
    XStremely XSive(Deceased)
    • Sep 2006
    • 426
    • Half way between Chili and Winter Wisconsin.
    Austin,
    Your sequence is correct, as for syncing at high rpms I have never found it needfull. I usually sync at 1000 rpm. If the bike won't idle at that speed to sync try a little higher. Once you have it synced you can decrease idle and recheck it. As John pointed out, once it is synced well you can lower the idle speed to well below 1000 rpm and it will still idle smoothly. My normal idle speed is around 800 rpm.
    The Old Tamer
    _________________________
    1979 XS1100SF (The Fire Dragon)
    1982 650 Maxim (The Little Dragon)
    another '82 650 Maxim (Parts Dragon)
    1981 XS1100SH (The Black Dragon)
    If there are more than three bolts holding it on there, it is most likely a very important part!
    • GARTHXS
      • 1631
      • Seattle
      sync
      I made my own sync out of a yard stick 12' of clear tubing a couple of wire ties and a coat hanger , throw in a couple of used pilot jet to minimize pressure an viola carbs are synced
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
      • 81xsproject
        • 3185
        • Fortuna, CA
        You can even go all out and make one with 4 tubes. Cheap and as accurate as it gets.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          no substitute
          Morgan Carbtune after a Gunson's Colortune
          Carbtune motorcycle carburetor synchronizers;polycarbonate tool pouchs;for motorcyclists
          XJ1100K
          Avon rubber
          MikesXS black coils
          Iridium plugs w/ 1k caps
          MikesXS front master
          Loud Horns (Stebel/Fiamm)
          Progressive fork springs
          CIBIE headlight reflector
          YICS Eliminator
            Re: Ahhh
            Originally posted by AustinPhoenix
            Just so I have the structure down, I will do the following:
            Petcock to PRI
            Fan on
            Warm up engine to proper temp
            Sync carbs 3 to 4 with the screw that's between them
            Sync carbs 1 to 2 with the screw between them
            Sync both pairs with the screw between 2 and 3.
            According to my manual, you should synch #1 to #2, #4 to #3, then synch 1&2 to 3&4 by the center screw.
            • Dragon Tamer
              • Sep 2006
              • 426
              John,
              According to my book he is correct. #3 is not adjustable exept by the idle adjust so you must start there.
              Garth,
              Thanks for the 6 billion pixel pictures of something that he cannot build in his rental unit.
              To the rest of you that won't believe what 40+ years of experience and the rebuild of over 300 bikes will tell ya--GOOD BYE!!!!
              The Old Tamer
                • 5047
                Uh...Bye. I suppose that I do agree that you can use one or four gages or manomenters or whatever. The end result must be the same -- vacuum balance at the low rpms end. When you are done with adjustments and recheck the readings they should be equal. Period. You don't like pictures dragontamer? I do. experience goes a long way and that should not take away from a man's credibility.
                Originally posted by Dragon Tamer
                GOOD BYE!!!!
                • AustinPhoenix
                  • Mar 2008
                  • 112
                  • Austin, TX
                  Oh wow...
                  I thought only oil, gas and tires started these heated debates. Guess we can add single/multiple vacuum tuning to the list too.
                  Thank you for all the responses. I love this forum. I should get her dialed in this week along with a 750 fd mod.
                  Safe Riding XSives!!
                  1980 XS11g Standard - "Ash"
                  4 to 2 Exhaust
                  K&N Pod Filters
                  Fuel Filters
                  Inline shut off valves
                  Slotted Rotors
                  My heart and soul
                  Soon to have stainless lines, xs750 FD, lightened rotors, and HID headlight
                  1979 Special Project Bike
                  Non-gasoline conversion
                  • GARTHXS
                    • 1631
                    • Seattle
                    non gas
                    What are you planning to use as fuel for your conversion?
                    91 kwaka kz1000p
                    Stock
