engine miss
  • gbsteph
    • Sep 2002
    • 4
    • Grand Prairie, Texas
    engine miss
    Help! My 79 xs11 misses at low speed while trying to maintain a steady speed. It seems to lurch more so than miss. It idles great accelerates great. I've colortuned it overhauled the carbs so many times I could do it in my sleep. No vacuum leaky. It will do it in any gear. I was wondering if anyone has seen this before.
  • chopper
    • Nov 2002
    • 167
    • scotland
    hi try checking the low and high tension circuits especially the pick up wires.also try your advance unit spray it with wd-40 or similar and watch it work,sometimes fine dirt can cause this to stick and give your symptoms,or even if the hose which connects this to engine is leaking that will do it.
    mick
    xs1.1s(x2)
    gsxr1100(1127)
    gsx1100g(x2)
    trophy900
    bonneville750
    http://www.tonyfoale.com/
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      Or the broken advance wires......check the tech tips.....
      Gary Granger
      • gbsteph
        • Sep 2002
        • 4
        engine miss
        Thanks for the input! The symptom is rather hard to describe. The engine seems to lurch rather than miss, similar to riding in high gear at a low speed when, which causes the bike to chug. I have already replaced the spark plug wires and rewired the pick up coil per previous info found here. (thanks) I have overhauled and adjusted the carbs numerous times. All jets and needles are correct and float levels are correct. It ran fine at one time and then suddenly began acting up. It must be in the mid range carb circuit, because idle, acceleration and high speed cruising are OK. In any gear while maintaining a constant speed is when it acts up. I have even used the colortune tool to adjust mixture. Anyone have any suggestions for flame color with the colortune that works best? And floats are adjusted from carb body base w/o bowl gaskets, right? I still ride it, but its not perfect. Thanks one and all for any tips !!
        Very Frustrated, Greg
        • Dragonrider
          • 1219
          • Garland, Texas
          Just some suggestions . . .
          Split/cracked vacuum advance hose?
          Bad vacuum advance pot?
          Vacuum advance line hooked up to wrong place?
          Ballast resistor (under tank on left) shorting or bad connection to the harness?
          Vacuum leak at manifolds (between carbs and engine)?
          Carbs are synced right?
          Bad/lose fuse box, main or ignition circuit?
          Good luck!
          CUAgain,
          Daniel Meyer
