diode question
    • 2117
    diode question
    The diode that is in my SG and others-What is the voltage that i need for repair purposes if it goes?I went to radio shack and saw 600v diodes and other ones.
  • Bob Falter
    • 321
    • Ely, Iowa
    A diodes voltage rating is its maximum operating voltage (600 volt diodes with work with 12 volts, 12 volt diodes, if there is such a thing, will not work at 600 volts) . I would think that any voltage rating over 200 would work for anything on the XS11 other than the secondary coil voltages going to the spark plugs.
    Bob
    #1 ’79 XS11 Special
    #2 ’79 XS11 Special
    '97 V-Max
    '01 Dyna T-Sport
      • 2117
      Thank-you.On payday i will go back to Radio Shack and purchase some so i can have a spare or two on hand.
