Have a 1981 XS1100 Special.
I can put the bike in gear without it running, And pull the clutch handle and everything works fine, Disengage and Engage.
BUT
If I have it running the clutch will not Disengage, When I go to put it in gear it will grind the gears, Once I have it in Gear AND Running, If I let out the clutch The whole bike Vibrates Bad and Sounds Horrible inside, If I pull the clutch handle it will stop doing this BUT will Still NOT disengage.
I did a search and found How to adjust the Clutch. I have tried to adjust it several times with the same result.
Any Ideas.?
Thanks
BUT
Any Ideas.?
Thanks
