another headlight question
    • 2074
    I looked at a couple of threads and was wondering-i jumped the headlight relay and got the headlights working but if i unplug the rlu the headlight goes off.Is this normal?Also the warning light on my SG that supposedly tells you if the headlight is burned out-does not light.If i remove the bulb then should this warning light work?
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Yes and yes. Maybe the warning light is burned out?
    I fixed my headlight relay.
    The white wire inside came off, so I resoldered it.
    I believe someone else had the same thing, so you may want to jimmie the cover off and have a look.
    XS1100SF
    XS1100F
      • 2074
      I took apart the relay.No wire just a spring loaded piece that has a contact on it.I guess when you energize the relay the contact hits the other contact.No wire inside whatsoever.
      • oseaghdha
        • 1075
        • N43.02.5,W88.14.2
        You can test it if you have a meter.
        Energize the yellow and black, see if you get a connect from blue to red(?)
        XS1100SF
        XS1100F
