78/79 cam specs
    78/79 cam specs
    I was wondering if anyone had a 78/79 book with the specs for the cams. I am running the 78 cams in my motor and want to try the later model cams (3H5). I have recently shimmed it up to specs with the 78 cams, but was wondering if I'll have to re-shim with the other cams.
    In the XJ's book, it says the total cam lobe width ( labeled B in my book) is 28.31mm +or - .05mm. If the 78 cams are the same dimensions, the shims should still be fine.
    I realize the cam LOBES are different, but you don't shim to the lobe. I'm wanting to know if the back side of the lobes are going to be the same.
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    cams
    Hey Tr. I have a set of 80 cams from this head, you are welcome to them (unless they make more power, I want them back!) Just kidding....anyways what really is the best head combo? I have read so many diff threads about this subject....Seems like just sticking on an 80 head with 78-79 cams Without boring does just as good as boring out the early or later motor ....Anyways...keep me informed....chop
    MDRNF
    79F.....Not Stock
      Thanks Chop. I have a couple sets of those later cams like you have, I have just never tried them. I have heard, like you, that the 78 cams improve performance.... but I have also heard it hurts??
      I was wanting to do a swap and see if I can feel any difference... but was worried about the shims.
      • mro
        • 4276
        • Hayward, California
        80 cams...28.31 mm
        wear limit 28.19 mm
        mro
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Re: cams
          So what is different about the 80 head ?
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Bullet
            • May 2007
            • 185
            • Alliston | Ontario | Canada
            From my Yahama factory manual ..
            78 cams ( 2H5 )
            B - Measurement
            28.341 mm +/- .05 mm
            wear limit - 28.19 mm
            80/81 head has bigger intake/exhaust valves ..
            Intake -
            38 mm - 80/81 vs 36 mm for 78/79 head
            Exhaust -
            32 mm - 80/81 vs 31 for 78/79 head
            I am gonna use a set of 78 cams on a 80 head .. got no choice .. my 80 cams are toasted from PO'ssss ..
            1980 SG - "Blue Balls"
            Complete Restoration - Finished June 21/2010
            - 1179 kit
            - 80/81 carbs 42.5/115 mains with XS pods
            - Mac 4 into 1 exhaust
            - Venture auto CCT
            - progressive fork springs - no air
            - Mike's progressive rear shocks
            - Galfer S.S. Brake Lines
            - XSDirect - Black Coils
            - 8 mm S.S. Core Plug Wires
            - T.C. fuse box
            - TKat fork brace
            - Geezer regulator
            - Battlax BT45 V-Rated tires
            - 5W40 - Rotella T6 Synth Engine Oil
            - rest of bike is "good old Yamaha"
              Thanks guys. Sounds like they should drop right in without having to re-shim. I'll check just in case though.
              • egsols
                • Jan 2006
                • 1090
                • Barrie, Ontario, Canada
                Bullett,
                I might have a spare set of 80/81 cams. PM me if you want me to check.
                Ernie
                  Tod, there is a .05mm difference in the intake valve clearence from the 79 to the 80, so right there you will need to change the intake side shims. I believe the 80's are a closer tolerance.
                    There was a discussion about this when I originally put in the cams as to which of those specs to use... the 78's since those were the cams.. or the later specs since that was the head and valves. I have always shimmed them to the closer XJ specs. That may be one of the problems I am having since I get a puff of blowback into the carb vacuum port where you synch them at.
