Oil Pressure
  • Fatman
    • 29
    • Albertville, Alabama
    Oil Pressure
    My engine is running between 10 pounds at idle and 35 pounds at 4000 rpms hot, is this good or bad??????????
    Fatman
    1979 XS11 Special
    72' 442 Conv
    49' Ford Custom
    Hey there Fatman,
    Your values sound a little low, the relief valve is set at 70 lbs, a fellow Xsive posted his is 60 cold, and 42 at cruising speed/rpm, and the manual states around 42 for cruising rpm.
    However, it might also depend on what type of oil, a lower viscosity range might show lower pressures than the higher range at the same temps!?!?
    Are you a fan of Jethro Tull by any chance??
    • Dragon Tamer
      XStremely XSive(Deceased)
      • Sep 2006
      • 426
      • Half way between Chili and Winter Wisconsin.
      Fatman,
      What TC said, sounds just a little low. What kind of oil and what viscosity are you running?
      The Dragon used to run about 55 to 57 cold and 40 to 45 warm but since I have been using the Sheaffer 20/50 synthetic blend it now runs about 25 at an idle and 45 at cruise cold and idles at about 35-40 and holds a steady 55 at cruise warm.
      The Old Tamer
      _________________________
      1979 XS1100SF (The Fire Dragon)
      1982 650 Maxim (The Little Dragon)
      another '82 650 Maxim (Parts Dragon)
      1981 XS1100SH (The Black Dragon)
      If there are more than three bolts holding it on there, it is most likely a very important part!
      • Fatman
        • 29
        I just changed the oil, had been running Castrol 20w50 motorcycle oil, this time I went to Lucas Synthetic, 20w50. Still the same pressures. Cold 45 at idle, 70 at 4000 rpms, hot barely showing any pressure (5 to 7) to 35lbs at 4000 rpms........ I am using a automotve type mechanical gauge, would that make a difference?
        Fatman
        Fatman
        1979 XS11 Special
        72' 442 Conv
        49' Ford Custom
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Where are you taking the pressure reading?
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Fatman
            • 29
            Rob,
            I replaced the Oil pressure sending unit with the mechanical gauge.
            Fatman
            Fatman
            1979 XS11 Special
            72' 442 Conv
            49' Ford Custom
            • 79XS11F
              • 3563
              OK ... there or at the side access pipe that goes to the head supply tube is where to do it. If your getting repeated low pressure readings and everything else is normal like oil level, on main stand, right type of oil etc ... you "may" want to consider pulling the oil pump and check it out.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • Fatman
                • 29
                Rob,
                Been a automotive mechanic all my life and have built cars and trucks for a livin', bikes are very new to me. Could the oil pump just need replacing or is the problem deeper? Cars having low oil pressure normally mean loose bearings, ie rods, mains, and camshaft............ am I close or way off base??????
                Fatman
                Fatman
                1979 XS11 Special
                72' 442 Conv
                49' Ford Custom
                • 79XS11F
                  • 3563
                  Everything you already know about engines from your auto background will apply to this engine. Bike engines are of course different in several ways but the basics still apply.
                  The low oil pressure issue could be ether the pump or the bearings or could even be that you will not get that 42 PSI you want until a certain RPM is reached. I can't even find the spec in my factory manual.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • boyat68
                    • Oct 2007
                    • 358
                    • Virginia
                    There is a page 7-13 in the manual that gives an oil flow diagram and the following information.
                    Relief valve opening 4.8 kg/cm squared (70 psi)
                    Cruising speed oil pressure (at operating temperature)) over 3 kg/cm squared (42 psi)
                    Oil warning light Activating pressure 0.3 kg/cm squared (4.2 psi)
                    Cruising oil temperature 102 degrees centigrade at 88 km/h (216 degrees F at 55 mph0
                      I have an OP gauge on my bagger, and the pressures are around 60 psi at all rpm when cold, and when warm, I have 60 at speed, and about 5-10 at idle.
                      • Fatman
                        • 29
                        I installed a SW gauge in place of the local parts store cheapy, I am getting about 5-8 lbs at idle and 45-55 at 4000 - 4500 rpms after she warms up. I also purchased some exhaust wrap, and a oil cooler, figure every little bit helps. I really do enjoy the bike, especially the power....................
                        Fatman
                        Fatman
                        1979 XS11 Special
                        72' 442 Conv
                        49' Ford Custom
