Petcock Rebuild - Eliminates Vibrations
  • Getty
    • Feb 2008
    • 127
    • Denver, CO
    Just like the title says... I am pleasantly surprised after rebuilding my petcocks. Ordered the rebuild kits from georgfix on ebay. They had everything needed for the petcocks and my silly octy thing.
    After rebuilding the petcocks and octy, I took her for a spin. Used to have this BAD vibration at 5-6k RPM and a leaky left side petcock. That vibration and the leak is gone! Who would have thunk it.
    Getty
    1980 SG
    What I want to know is, is your headlight brighter? Sorry, I couldn't resist.
    • Getty
      • Feb 2008
      • 127
      • Denver, CO
      Hmmm. Havnt noticed the headlight getting brighter. Do you think i would lie about vibration?
      Getty
      1980 SG
        No sir! I just can't imagine the connection. I could be that a plug wire was shorting to ground and in the process of the repair, you inadvertantly moved it to a better position. :-)
        • Getty
          • Feb 2008
          • 127
          • Denver, CO
          Dont think plug wires. I took care of the plug/wire repair several months ago. I guess anything is possible. The vibration I had was intense at 5-6k RPM. Nothing changed after I fixed the plugs/wires.
          Getty
          1980 SG
            Skids, He was probably STARVING one pair of carbs, so the engine was NOT producing a "balanced" power. That IS one way to induce vibrations into a bike.
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              If the engine was being starved for fuel it would vibrate and with that issue now corrected it likely does run smoother and should also have more power.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • Getty
                • Feb 2008
                • 127
                • Denver, CO
                The bike does have a little more power. And it's smoother, mostly at higher speeds. A bit more fuel friendly as well. 39mpg
                I tried searching for vibration problems a few months ago. Didn't find anything related to petcocks. Hopefully this will help another XSive noob.
                Getty
                1980 SG
