Rear Tire Width?
  • rootnp
    • 31
    • York, PA
    Rear Tire Width?
    What is the widest tire that will fit on the XJ. The tires I have on there now are 130/90/16
    I'd like to go 140/70/16 Does anyone know if this will work?
    Thanks
    "82 XJ1100 Darkness"
    K*I*S*S
    Re-jeted
    POD Filters
    SuperTrapp 4-2-1
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    From what I've read a 140 should fit as long as it doesn't have raised letters on it. A few have expressed concerns about it rubbing only during cornering due to the side loads. It will be tight. I've read about spacing the rim out away from the swing arm and then shifting the whole swing arm left to keep things centered for more clearance but haven't done it myself. Going to a 70 series will mean the tire will be slightly shorter then stock, look for a 140/80/16 to keep things at stock hight or a 140/90/16 for slightly taller then stock. Remember the standards came with a 17" rim which makes the tire a full inch taller.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
