What's happening here?
  • grant1856
    • Jul 2007
    • 23
    • Sacramento
    My bike is not running as well as it should. I noticed that the far left pipe is not hot after it is running for a while. Any ideas?
    Thanks,
    Grant in Sacramento
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    If it has spark... then chances are the carbs need cleaning.
    Note the plural... for if one's bad, the other's aren't far behind it.
    Could be a valve... do a compression check and check your valve clearances.
      • 5062
      Re: What's happening here?
      Look at the plug. It will tell you a lot.
      Thanks,
      Grant in Sacramento
      • Gyrogearloose
        • 162
        • Coupeville, WA
        BTW do you have inline filters on your bike?...if not I surely would install them, otherwise you may be in for repeated carb cleanings; a PITA.
        Geno
          • 5062
          That is affectionately referred to as, "carb hell."
