I've been playing a lot with my carbs trying to get this thing running right and It seems like I'm stuck between two different main jets.
The bike has aftermarket 4 into 2 exhaust and stock air box. I'm running ngk iridium plugs, when I got it the pilot circut was screwed and iridium's kept it from fouling out all the time.
I should also mention that this bike may have other internal mods, I got it used of course and it has about 165lbs compression on all four cylinders with the carbs off. That seems high for a bike with 40,000 on it, especially when clymer says it should be under 150.
I have both 137.5's and 140's. With the 140's in the bike seems to pull better WOT from about 2500 - 5000 RPM but then not as hard from 5000 up.
According to what I've read this doesn't make much sense as the needle should be the primary influence in that range. The plugs look a little dark, not nice tan but a touch gray/black.
With the 137.5's the bike seems to pull harder from 4000 - all the way to red line then it does with the 140's but at 7000 - 8500 I can hear a miss, also the plugs are very light, not bleach white but whiter then I'd like.
I've read the factory pro tunning site and it seems like our xs are in between the directions for High/low RPM bikes. Does anyone know what RPM ranges are effected most by what settings. The site seems to suggest Main jet selection should be based on 7.5k - 8.5k on our bikes. Based on that I should pick the 140's as they get rid of the miss but I really think they are to rich. Maybe go with the 140's and drop the needle one position?
Anyone know what RPM the needle stops effecting WOT operation? Its easy to tell that we go off the idle circut at about 3-3.5k. Should I assume that we transition from needles to pure main jets around 6.5 - 7k because thats where I get the miss with the 130's?
Maybe something like this:
WOT idle - 3k float hight (from factory pro)
WOT 3k - 6.5k needle position (my guess)
WOT 6.5k - up main jet (my guess)
Any input or suggestions? Its really hard to tune by seat of the pants feel when I don't really know what a good running xs feels like.
Enricher circut does have some effect above 2,000 rpm, just how much don't know. Something I will check into when I figure out how to test it.
