Boss Noss XS1100??
  • T99Ford
    • 678
    • Bozeman,MT
    #46
    At your elevation, do you have to mix race gas in order to prevent pre-ignition with the nitrous? I have been able to get by on 91 pump gas in my sled, but that is from 6-10,000 ft. I suppose that you could be riding at that height in CO. I
    I have been very happy with the Boss system on my sled. I imagine that the bike would be the same. I think that in my application, a turbo would be better than nitrous, and much mre useable. Nitrous would come later
    Where did you pull lube oil for the turbo from? The other question I have, is were you able to get the intake manifold from harley, or did you have to make one.
    Thanks for any info!
    Tyler
    Healthy is merely the slowest rate at which you can die
    Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
    • JustJeff
      • 61
      • Golden Colorado
      #47
      Fuel
      I have too much compression to run pump gas and a turbo 10.25-1.
      It also limits how much boost I can run.
      I did add a couple base gaskets once to the cylinders to lower the compression, but it made it hard to start and increased the boost lag.
      It is setup to run 8lbs of boost right now but it will run quite well at 12lbs. That much boost also requires an even higher octane (116) and true leaded fuel. That is where I made my big numbers on the dyno.
      However Nitrous likes compression and it naturally cools the intake temp.
      Altitude, I have lots. I am at 6200 ft and right on the foot of the rockies.
      I am using a very modified RC engineering kit the intake manifold plenum was ready made. The actual intake manifold that attaches to the carb bolts to an adapter plate that bolts to the turbo (the manifold comes with the carb)
      The oiling comes from the oil feed that goes to lubricate the head. it return flows to the oil fill plug.
      It's raining today but when the weather clears up I'll take a pic or two if you want.
      Obsessed Motorcycle Mechanic / 29 year Owner of a 78 “E” model
      Restored 1196cc Turbocharged 211 BHP @ RWL
      “Honk if you have never seen a gun fired from a motorcycle”
      • T99Ford
        • 678
        • Bozeman,MT
        #48
        Please take a couple of pictures. I'd really like to see what you've done.
        • JustJeff
          • 61
          • Golden Colorado
          #49
          I don't know how to upload pics but I put them on photo bucket.
          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
          • JustJeff
            • 61
            • Golden Colorado
            #50
            Hit the send too soon
            Pics: Pics of my Bike
            78E model
            90% gloss powder coating
            Jaguire metallic red w/ gold pearl (pics don't do justice to color)
            Hand airbrushed Skulls (you need to understand my painter)
            wrinkle powder coated cylinders and head (black)
            1196 Big boar engine 10.25-1
            Falicon super-crank mods
            Carillo rods
            Ported Head
            Stainless Valves
            Kibble white Springs and tops
            Megacycle Cams (Some creative Degreeing for the turbo)
            Undercut gears
            Billet clutch basket w/ 9 alto "red" plates and Heavy springs
            R/C engineering Turbo Kit (some of it is still original)
            Rajay Turbo
            Tail Wastegate 8lbs (right now)
            Mikuni HSR 45 Flat slide carb
            EBC Premiere Free floating rotors
            Progressive fork springs
            Vmax shocks (will end up with progressives but these work surprisingly well)
            Tell me what you think
            • Shuriken
              • 1093
              • Southwest USA
              #51
              Looks great. How does it perform? Have you raced it against anything?
              Formerly:
              1982 XS650
              1980 XS1100g
              1979 XS1100sf
              1978 XS1100e donor
              • JustJeff
                • 61
                • Golden Colorado
                #52
                performance
                Runs REAL STRONG
                It is still a heavy bike compared to modern sport bikes.
                I run out of gears way before most sport
                bikes.
                30 -130 it is very hard to beat.
                I have gone up against a friend on an R-1.
                He beat me out of the hole and I had a hard time making the difference before I ran out of gears (almost). But. 30 mph roll -on and he got small in my mirrors till about 130.
                • Paintman
                  • Mar 2008
                  • 312
                  • rapid City SD
                  #53
                  Boosted
                  very nice jeff very clean install, has to be a blast to ride we use to exeriment with turbos when i was in school for Honda in the 70"s.very nice Bike
                  John
                  79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
                  80 XS1100 S Project gonna be a hot rod
                  06 CBR1000RR sold!!!!!
                  2000 Concours
                  84 Kawi KLR600
                  79 Yam XT500 Ouch it kicks back
                  79 XR250
                  Why is it that the smallest part can fly to the farthest part of the shop?
                  John
                  • Shuriken
                    • 1093
                    • Southwest USA
                    #54
                    Very nice. What made you choose the XS to put your time and money into?
                    You still have the shaft drive. Imagine not running out of gearing after doing the chain drive mod! Perhaps your bike would benefit from a 750 rear end swap?
                    Formerly:
                    1982 XS650
                    1980 XS1100g
                    1979 XS1100sf
                    1978 XS1100e donor
                    • JustJeff
                      • 61
                      • Golden Colorado
                      #55
                      Being different
                      Anybody can go out and buy a busa and bolt on a bunch of parts and have something sickeningly fast. It will also be like every other bike out there.
                      No real skill involved, No challenge. Somebody else has done all the hard work for them.
                      Doing this much to an XS11 and getting this much from an XS11 requires actually knowing what you are doing and WHY it needs to be done that way.
                      Modern sport bike riders don't respect old-school bikes... That is till one of them bloodies their nose LOL
                      • The Lorax
                        • Jun 2005
                        • 1048
                        • Riverside, OH
                        #56
                        Well, Jeff, it would seem that you know your stuff. your bike is banging, wish I knew half as much about how to make stuff go faster and such. props man, me gusta mucho.
                        I am the Lorax, I speak for the Trees
                        '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
                        '79 XS1100 F R (IL Barrachino)
                        '00 Suzuki Intruder 1400 (La Soccola)
                        '77 KZ400s (La Putana)
                        • Mathh
                          • Nov 2006
                          • 699
                          • Beek, Netherlands
                          #57
                          Nice bike! And good to see the RC engineering kit, very rare! I have only see them twice on an XS1100 as long as I can remember.
                          MV Agusta Brutale 910R '06.
                          Yamaha MT-09 Tracer '15 grey.
                          • JustJeff
                            • 61
                            • Golden Colorado
                            #58
                            Turbo Kit
                            Thanks for the complement Math. That is high praise coming from somebody who built the monster you did.
                            The RC kit I used I found in new condition. I wanted it BAD. I actually got it through a trade deal (would have traded my Kidneys). It short cut everything I was trying to do. The pipes and plenum are stock everything else has been changed at least once, to one degree or another (waste gate, impellers housings ect.)
                            I have been looking for a good Ignition system that will give me some additional tuning capability like boost retard and variable advance rates. Looked at a few but tring to balance price with function.
                            What did you use?
                            • Mathh
                              • Nov 2006
                              • 699
                              • Beek, Netherlands
                              #59
                              In 1994 I had the Electromotiv Tec I installed. It incorporates 2 direct fire units instead of the standard coils. The injection and ignition are both programmable and are interconnected. With the previous Haltech system I tried the standard coils interfered with the ignition so I could not get it to run at all (only with the coils 2 ft from the bike ).
                              The tec I is old compared to the new products they offer now, but it does the job.
                              • psycoreefer
                                • Feb 2008
                                • 1557
                                • Minden, NV
                                #60
                                Hey, I don't have any experience with NOS or Turbos but if your looking for a programmable ignition/injection setup you might want to check out the Megasquirt. Its DIY and as programmable as you'll probably want. Someone even fitted one to an XS already, there should be a link to the guys web page in the tech section somewhere.
                                1979 xs1100 Special -
                                My Bike:
                                [link is broken]
