cleaning old grease off final drive and drive shaft splines
  • cleaning old grease off final drive and drive shaft splines
    Other than trying to wipe it off, is there any solvent that is recommended? I've been told brake cleaner, mineral spirits, etc...but was worried about leaving a residue that might break down the new grease. Never had the rear wheel off before, so could use some advice.
    Thanks!
    1980 XS1100SG
    “You start the game with a full pot o’ luck and an empty pot o’ experience... The object is to fill the pot of experience before you empty the pot of luck.”
    Only a Biker knows why a dog sticks his head out of a car window.
    Brakleen leaves no residue.
      thanks Prom
      1980 XS1100SG
        An old tooth brush helps too.
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
