front wheel stuck
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    front wheel stuck
    Sorry, stupid question time. Darned if can remember how I removed the front wheel last time. Tire is a 110 instead of 100 and I do remember it being a tight fit. I have it deflated, calipers off and fender loose and I can't squeeze it out between the forks. I don't really want to loosen fork brace or anything else just to get the stupid tire off. Or do I have to??
    It's new tire time for XS East....
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    front wheel removal
    On the Specials, you have to turn the fork legs to get the wheel out, which unfortunately means removing fender and fork brace.
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      Yep, that's what I figured. It's off, now just have to remember the proper retightening order. Geez, can't remember a thing anymore! Thanks bikerphil....
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        tightening order
        First, tighten left side castle nut. 2nd, center rt. rotor in caliper bracket (fork) and tighten pinch bolt. Last, put on fender, then fork brace. P.S. Make sure speedo hub is in it's slots before tightening castle nut.
        • newc4
          • 643
          • Vienna VA
          I've just done this on my 79SF. If you've a Tkat forkbrace you just have to loosen it and the fork tubes should rotate easily thoough it still takes some manuevering to get the tire out.
          Darrell
          Darrell
          78E
          80G project
          06FJR
