Carb synch - alternate fuel tank
  • Chuckster
    • 93
    • Crystal Lake, IL
    Doing my first carb synch and I was going to use an alternate fuel tank. (regular tank off to be painted). I'm guessing I will have to install a "T" fitting on the line from the alternate tank and run it to each of the fuel lines that would normally connect to the petcocks? Is that right?
    Chuckster
    '78 XS1100E
    Money can't buy happiness, but it can get you an XS11 and that's a start.
    Yes, you will have to run a "T" if you only have one fuel petcock on the tank. DO NOT FORGET TO RUN A FAN to keep the motor cool while you sync the carbs!! You can over heat the engine in five minutes!!
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      I went to a lawnmower wrecking yard and got a tiny tank for an aux. tank.
      I use a T to the 2 carb hoses. I bungee it to the frame where the regular tank goes.
      Test rides look funny.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        one line
        I use one line only from the aux fuel to the res line on my XJ
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • HobbyMan
          MeatHead Idiot "GURU"
          • 1801
          • Colleyville, TX
          I am lazy. I have a few feet of line that fits snugly over my gas can vent. That goes to a T. I set the gas can on the luggage rack. Just tilt it over and you can use all the gas you want. No pouring or messing around.
          Acta Non Verba
            I haven't used an auxiliary tank for syncing since I replaced my fuel lines and cris-crossed them so the right petcock feeds the left carbs, etc. I left the lines long enough so I can prop up the rear of the tank on a 2" block of wood. With the sync tool connected to the manifold nipples, I put the petcocks on prime for fuel flow.
            YMMV..
            • 81xsproject
              • 3185
              • Fortuna, CA
              I too just use the wood block and a small stubby screw driver.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                Since I am plumbed sort of straight in from my petcocks I turn the tank around and put it where the seat was. Opens up the whole top of the motor for easy access.
                Mike Giroir
                79 XS-1100 Special
