Ok, I've read all the vacuum leak threads and idle creep threads and cannot quite find the answer..
I've got 79 standard XS1100 with pods. Where do the top carb tee connections go to if not using an airbox? The petcocks?
Also, the idle creeps up when cold but the boots are good (tried with other carbs). Where do I start to look on the carbs for problems. They've been triple cleaned, new needle valves installed, diaphragms are good...
Thanks,
Tom B.
Thanks,
Tom B.
