Oil Temp Gauge
  • danteinien
    • Mar 2008
    • 101
    • Utah
    Oil Temp Gauge
    Do you guys think somthing like this could work? Perhaps in the oil fill hole?
    http://cgi.ebay.com/ebaymotors/OIL-C...QQcmdZViewItem
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    If it has been designed for a Harley the XS might reject it like a bad liver transplant.
    Serioulsy though, I have seen gauges made for the oil fill/dipstick holes specifically for Japanese models. But I think they were all overseas.
    Ernie
    • oldnortonrider
      • 448
      It's an excellent, superb idea, in my opinion, except, from the looks of it in the pic, I'd guess that the tube-stick would not reach the earl. And the push-in neoprene part looks to be too large size for the XS oil hole (?) Altho, that could be "re-modded". To rig up an oil temp gauge, somewhere on my machine, has definitely been on my agenda. And an oil pressure gauge.
      Not sure if the stick would be a good enough miss from clutch basket, and still be down in a big enough pool of oil to get the job done.
      JCarltonRiggs
        The Yamaha parts book in '78 used a VDO oil temp. It was electric, so it replaced the oil drain plug with the sending unit, and a single wire clipped on. Worked really well on my original bike.
        • oldnortonrider
          • 448
          "on the '78s"........and electric. Good to have that info.
          JCarltonRiggs
            My Bagger has an electric oil temp gauge in it. The sender is mounted in the oil drain plug.
            I'll bet you could go to an auto parts store, and be able to source a gauge with metric treads on the sender and bushing.
            • oldnortonrider
              • 448
              John; what temp range do you get with different ride conditions?
              JCarltonRiggs
                I have seen it get up to 220 after a long ride. It also has an oil pressure gauge, and I have noticed that the oil pressure will drop from about 60 PSI to 20 PSI after it heats up also.
                • thewiz
                  • Oct 2006
                  • 1115
                  • Wilksboro, NC
                  Well ...
                  I have one of those that came with one of my XSs ... kinda' hard to read while riding but it does register
                  80G Mini-bagger
                  Past XS11s
                  • oldnortonrider
                    • 448
                    OK; I appreciate the number(s) input.
                    JCarltonRiggs
                      Mine was done before I bought the bike, and the swivel bracket is mounted to the upper tree somehow, and the gauge sits just below the handlebars. It is a pretty slick install actually. The light in it works, and is easy to see.
                        Here's some pics of the gauges
                        Oil temp gauge from the front
                        Oil temp gauge from side
                        The gauge on the lower left is the Voltmeter, the Oil pressure on on the lower right.
                        • stevec5000
                          • Oct 2002
                          • 131
                          • Mesa, AZ
                          I also have VDO oil temp and pressure gauges but the senders are installed in a T that I put in the line to the oil cooler.
                          72 TS185
                          77 XS750
                          78 SR500
                          80 XS850
                          80 XS1100 Midnight Special
                          81 Seca XJ750RH
