okay here is the problem it is a 81 1100 midnight special. when i crank it up the the rpm gauge works for about 5 seconds to a min. then the gauge falls... i turn if off then crank again and it will work for a min again... any help...
not charging
Tags: None
I JUST solved a non-charging issue where my tach worked fine and the headlight stayed on all of the time, but the battery would be stone cold after about 35 miles.
Recently, I had the bike apart for paint. Covers, engine off, wheels off, etc...
Apparently, when replacing the cover over the generator, the wires got pinched between the cover and the engine block. This caused a breakage in the wire, which I repaired. Charging system now throws just over 14 volts across the battery and I can once again see at night!! Who knew there was so much to look at??
"Rat Rod"
79 XS1100 Standard
87 VMAX cans
Cheap Japanese Tires
Cobalt Blue Rattle Can Paint
Custom Lighting on a Budget
Perry Center Fire Department
Perry Emergency Ambulance
"If we don't do it, who will?"
Some people have one of those days, I have one of those lives...Comment
yeah my headlight isn't working.... i was going to by pass that unit... so hopefully that is it... i guess i will find out this weekend...
thanks guy
bbComment
