Spark Plugs
  • xsilerating
    • Dec 2006
    • 431
    • Eastern Ontario, Canada
    Spark Plugs
    A question of clarification from someone... anyone... who knows.
    What is the difference between the owners manual recommended plug - NGK BP6ES and, NGK BPR6ES ?
    Also, are there any problems, or foreseeable issues, using the BPR6ES plugs? I've asked the store employees but, no-one could provide an answer.
    Thanks?
    1980 XS11 LG (Diablo)
    1980 XS11 G (Bagger)
    1978 XS11 G (White Knight)
    1978 XS11 G (Skeleton)
    2016 SS (S.S. Flyer)
  • mro
    • 4276
    • Hayward, California
    Click here >>> http://www.ngk.com/sparkplug411_ngk.asp
    mro
      Basically, the BPR plug is a resistor plug. It would be the one to choose if you have an onboard radio. This will give you less engine noise through the speakers. Either plug will work though.
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        resistor plugs
        If you have resistor caps and resistor plugs ,you may be reducing your spark a bit . I had to consider this when going to Iridium plugs . If you want more performance that makes up for the extra resistance ,try Iridium . BPR6EIX , I think . (6637 at NAPA)
        As the stock coils are considered somewhat weak from the factory ,I plan on getting some from MikesXS and going with no-resistor caps or no caps at all .
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • xsilerating
          • Dec 2006
          • 431
          Thanks All
          As usual, the XSive bunch comes through.
          • tommystinson
            • Aug 2003
            • 425
            • Albany, NY
            I run the Iridium plugs myself, along with Accel coils. Big fat spark, to be sure.
            2010 Kawasaki Z1000
            1979 SF: Millennium Falcon, until this Saturday
              The nice part is the resistor version of the plug is the same one used in a 1997 Honda Accord 4 cyl! Can you say any type plug you want, if it's resistor!
