Bypassing starter button?
  • Pain
    • 476
    • Milwaukee, WI
    On my continuing efforts to get my xs1100h running, I am really thinking it is the starter button, but want to be sure. Since the plug from the starter on my SG is different, I can't just swap out a known good one, and want to try and bypass the button and kill switch all together.
    I did some searching and didn't find anything, and it is no good showing a wiring diagram since I can't make heads or tails of one.
    I know (kinda) that the killswitch interrupts the ground, so if I connect those to wires at the plug on the harness it should be the same thing (right?). The blue wire then needs something, is it just being jumped to a 12v power source? I figure I better ask before trying this.
    Before anyone points it out, I have replaced the solenoid with a known good unit (off the SG), and it did not help. Volt testing at the starter button did not register anything.
    Thanks
    I've been in more than one Hemisphere, and I wrote a book to help you do it too (or just prepare better for that week long road trip). Going Small, not just for the little guys.
    • 8891
    by-passing starter button
    Find the blu/wht wire on the solenoid (soldered on). This is the wire that goes to the starter button. If you take a jumper wire and touch that blu/wht solder joint to ground, the bike should crank (key on, kill switch in on position).
    • Pain
      • 476
      • Milwaukee, WI
      Is that how to bypass the starter button? I want to include enough of the wiring to rule out only the starter button.
      And actually having the bike start would be good too.
        • 8891
        by-pass
        Well, then find the blu/wht wire at the starter button and ground that. If grounding that wire doens't crank the bike but by doing as I mentioned earlier does, then that blu/wht wire is NFG!
          You may want to check and see if the ground wire for the switch housing actually makes a good ground. It will be the black wire that is screwed to the switch housing. The switch housing is not case grounded. If you ground the bl/w wire, it should crank. If you ground it at the solenoid, and it cranks, then run a ground wire from one of the screws that holds the switch housing together to a known good ground (like the battery). Try the starter button again. If it does crank, then check the connection for the switch under the tank. The switches do not have a connection in the headlight bucket.
